Clean my Mac Pro
How do I take off the side panels and get the dust out of my Mac Pro computer (desktop) ?
Mark
    Novelist:
  • 142 Answers
All of the recent mac pro's have a little handle you lift up on the left side, and the side drops down. This is true of G3-Intel. Which model do you have?
Posted on Sep 07, 2009
Why doesn't power button on mac pro desktop computer work When computer is plug in and button pushed?
This may be a broken button. Not a terribly hard fix. I once fixed a computer and put a giant red button on the side they could hit to turn it on. Customize it!
Sep 11, 2015 | Computers & Internet
How do I clean the dust out of my PC?
Turn the pc off and unplug all the wires and peripherals that are attached onto it.
The desktop chassis should have a side panel that comes off, that is screwed onto the body. once you get the panel off, you can use a can of compressed air to get rid of the dust and debris from the fan, air vents and the heatsink.
Here's a pretty neat tutorial with do's and the dont's, on how to go about cleaning your desktop. give it a read before trying it out.
http://www.wikihow.com/Clean-the-Inside-of-a-Computer
Jul 16, 2014 | Acer Aspire Computers & Internet
My mac Pro Desktop mirrors the monitors all by itself. It also turns the volume up and down by itself. Is this hacked??
Have you checked or unchecked the turn mirroring on in display preferences? Sound output settings: be sure you are set for internal speakers and not one of the other options (unless you are using USB or some other output device). This is not a hack: Hackers want to use your machine to send email or style your data. They don't care about monitors.
Also try repairing permissions in disc utility, and then repair the disc. If that fails, run Disc Warrior and clean up the system.
Jan 23, 2013 | Apple Mac Pro 8-Core Desktop Computer...
File with ? mark in Mac OS x Lion.
The clicking sound is probably the hard drive trying to find the boot sectors. You should be able to open the DVD drive by holding the (wired) mouse button down while turning the computer on.
Apr 11, 2017 | Apple Mac Pro A1186 Desktop
Will not read/recognize memory stick pro duo card
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Jul 21, 2011 | Computers & Internet
When I plug usb flash drive into my mac nothing happens. Do I need to format stick first? If so How do I format? How do I get stick to show up? Can I even use this with my G5 mac? Should I just return...
i am not sure about a mac but you will need to install it first so you can use it
if you cant see your usb drive you will not be able to format it
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format hope this helps
Jul 20, 2011 | Computers & Internet
I plug in the flash & my MAC computer computer does not see it...nor can I find it..but when removed...it says that device was not removed properly...please help....Thank You Jilli
im not sure about a mac computer but i no with windows you should remove the hardware safely device when removing any hardware if you finally get it back right click and see wahat options are there in windows the safely remove hardware is a small arrow on the bottom right of the screen
this is for windows im not sure about mac computers
hope this helps
May 22, 2011 | Computers & Internet
Casing getting hot, fan going mad then slowing down
Have you ever removed the side panel and cleaned out the dust from inside the computer case?
If your fans or air inlets get clogged up with dust then your machine will run very hot and could eventually shut down or cause permanent damage.
Unplug all the cables from the back of your pc, and remove the 2 screws from the back panel that secure the side panel. Then just pull back on the side panel and it will pop off.
Clean out all the dust from inside the case. You can use a vacuum hose but don't bang into anything with it. Also use a small clean paint brush to lightly brush the dust off of the fan blades and the CPU heatsink and around the power supply air vents. You can also use a can of compressed air if you have it to dislodge the dust and then **** it up with the vacuum.
Good luck and please comment back and RATE if this was helpful.
Feb 05, 2011 | HP Pavilion Slimline s3500f Desktop...
Fans on Mac Intel Tower
I would suspect it needs a good internal cleaning. The accumulated dust will cause the computer to overheat. Disconnect all cables and take the unit to a place where you can clean it. Remove the side panel and then with a can of compressed air or an air compressor blow all dust out of the unit. Pay special attention to the heat sink on the processor. Make sure you clean the power supply fan. Be sure and not touch any internal components without first grounding yourself to the chassis. It is best to do this outside as the dust will fly everywhere. You should clean the inside at least once a year. Merry Christmas.
Dec 15, 2009 | Intel Mac Pro Tower Desktop
Blinking white lite won't really power up monitor says no signal and the fans start slowly then gradually increase. we had taken the side off to clean out the dust and dog hair and when we put it back...
Clean your memory card. its edge connector with soft eraser both side. Do this after you power off the unit and unplug to wall socket. Take out the memory and do the cleaning.
May 12, 2009 | Apple Power Mac G5 Desktop
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
