Question about Refrigerators
Icemaker overflows into holder freezing
Icemaker overflows into holder freezing everything togeather
  • 4,070 Answers
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Posted on Sep 07, 2009
  • 612 Answers
You water valve is seeping. You will need to replace it. It's pretty simple to replace. It is located at the bottom of your fridge around on the back. Look for the piece that the water line coming from your house goes into.
Please rate solution.
GE profile refrigerator pss266msra has a problem with the freezer. Replaced the thermistor and heater as suggested since I had ice buildup. Now icemaker is leaking water which is freezing into icicles -...
One of two things is happening.
1) the fill tube leading from outside the box into the icemaker may have ice buildup or is too close to the icemaker fill wall. Make sure there is a gap between fill tube and wall and check for ice in the tube.
2) wait for the icemaker to call for water and see how long is calls water for. It is only suppose to be 7.2 seconds. If it calls for water longer it can be overflowing. If overflowing than replace icemaker.
Usually there is ice buildup or something that the water is hitting and splashing everywhere.
If you have anymore questions or need more assistance please comment.
Aug 01, 2011 | GE Refrigerators
Ice maker freezes but does not dump then fill again cause overflow.
If there is power to the icemaker and is not turning, the most likely problem is the icemaker timer has gone bad Contact your place of purchase or an authorized parts facility for a replacement.
They are usually very easy to replace yourself.
Jan 10, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Makes ice for three days, water drips to fan, freezing up,
there is a device like a switch that makes the icemaker stops the solenoid valve of the water intake, u should check that switch...
Mar 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water over flow
Depends on the model. It could be a water switch that is sticking or a motor in the icemaker running to slow. My advise is to replace the faceplate of the icemaker. Part #150
Jan 16, 2009 | U-Line Icemaker
Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Dec 16, 2008 | Amana Refrigerators
Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Nov 02, 2008 | Kenmore 53642 / 53644 Side by Side...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
