Question about Mpio FY500 MP3 Player
Invalid memory - Mpio FY500 MP3 Player
  • 77 Answers
Probably memory is format is damage
Posted on Sep 07, 2009
Hi, i have an issue when trying to open AS400, it prompted me "userpmd.dll Error code:998-Invalid Access to memory". Any ideas?
When a 32-bit application runs on a 64-bit version of Microsoft Windows Server 2003, and the application calls the LsaLogonUser function to authenticate the logon data of a security principal by using stored credentials information, the function may return the following error: Invalid Access Memory Location (998)
See the Microsoft link attached
May 27, 2014 | IBM Computers & Internet
Touch screen working
May be your phone is locked with some particular network.Hence when you insert other networks it shows the error message "Invalid Sim"...If you want to use the Samsung C3303 with other networks you need to unlock it.To unlock you can approach Simpleunlocking.com and get the requires unlock code along with free unlock instructions.
Aug 27, 2013 | Samsung C3303 Cell Phone
Hi! I have problem with my compaq armada M700.when i turn it on writing comes out "INVALID MEMORY MODULE PLUGGED IN!" Can you pls.help me what to do?
Sounds like you either have a bad memory module or else it isn't properly seated in the memory slot properly.Access to memory slots in laptops can be as easy as taking off a panel, or as difficult as taking ff the keyboard. Sometimes, one slot us under a simple panel, and the other one is under the keyboard. If you are mechanically inclined, you may want to remove and reseat any memory you find under a panel on the bottom.There is a "how to" here that shows you how to remove and replace a memory module in a laptop:http://www.ehow.com/how_5468843_change-ram-laptop.html
Mar 02, 2012 | Compaq Computers & Internet
My samsung gtC3010 shows "invalid data " when i
then first go to memory settings ->default memory ->put all respective browser memories to memory card...like wap downloads etc.
Oct 17, 2011 | Cell Phones
I tried turning my mp3 player on and it said "invalid memory, cant find MBR"
Invalid MBR = Invalid Master Boot Record.
This means that your player Flash Memory drive is corrupted and unfortunately may need to be reformatted if you cannot repair it using some Disk drive or Flash drive utility.
You can try to use 'Properties -> Tools -> Error Checking -> Check now' to fix the issue.
If you have a backup of the music on your player, I would simply use Windows Explorer and FORMAT it using FAT32.
Hope it helps.
Dec 22, 2009 | Mpio FL300 MP3 Player
How do I clear ERR: INVALID DIM
Reset memory to default, the error will disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps
Sep 10, 2009 | Texas Instruments TI-83 Plus Calculator
Error invalid dim
Hope it helps
Sep 06, 2009 | Texas Instruments TI-83 Plus Calculator
DISPLAYS ERROR MESSAGE: W2 INVALID PERS. WHAT DOES THIS MEAN AND HOW DO I GET IT TO PRINT?
FROM THE SERVICE MANUAL
W2 INVALID PERS:
The job was not printed because the requested personality,
such as PostScript, was not installed. Install the language in
which the files are sent, together with enough memory to
support that language.
I SUGGEST CHECK IF YOU GOT THE POSTSCRIPT INSTALLED
May 04, 2009 | HP LaserJet 4 plus Printer
Dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
may be ur pc not supporting 1gb so make it small means get less than 1gb than try.
Nov 27, 2007 | Intel AC450NX Server
Mpio FY500 MP3 Player Logo
78 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
