Question about Clark Forklift Horn Button Switch , Cat Etc
AFTCO Forklift Clutch
G'day, I've got a problem with an AFTCO Forklift Clutch. How to adjust, or how does it work. 1.4ton AFTCO probably made in about 1973. Manual trans. It has a lever that is pulled by the clutch pedal at the side of the bellhousing and a rod that is pushed into the centre of the bellhousing. I have tried to adjust them both to give more pedal travel and more movement on the lever at the side but it still will not go into gear. I have to turn it off to put it in gear and start it up with the clutch in. When I do this it does not creep or drag but I cannot use the clutch to put it in gear when engine is running. Because it grinds badly. A diagram or exploded view of all the parts that make up the clutch assembly would be handy. Any advice etc. would be greatly appreciated.
Cheers from Cameron in Western Australia.
  • vg265 Sep 30, 2009
    Howdy avid101. The clutch arm is pulled by the rod from the clutch pedal. I have had some success with the clutch lately. When I first got it the previous owner had adjusted it so that the pedal could only travel a short distance because the pushrod into the centre of the clutch was adjusted too long. This didn't allow the clutch arm to move far enough to disengage the clutch. My adjusting allowed the clutch arm to move the correct distance. The next thing I looked at was idle rpm. It's got a Holden 173ci 6cyl
    running on petrol. That's an Aussie GM engine. Anyway
    it's meant to idle at 500rpm. So then I did some tuning: float level on Stromberg, points, timing etc.
    Now sometimes it will go into gear without crunching.
  • Bruce Hathcock May 11, 2010
    good Day Their Mr. Aussie, I think if it is same as the U.S. counter part it works in reverse so you adusted in the wrong direction, can you tell me when you push the clutch pedal in does it pull or push the clutch arm?
2 Suggested Answers
  • 42705 Answers
SOURCE: I have a clark dpm20n forklift that wont go forward or backwards. Can anyone give any advice? Thanks
clark forklifts have a safety device on the brake pedal hydraulics that prevents movement when lifting the forks
check the operation of that safety device as it may be jammed in the neutral position
Posted on Mar 14, 2016
What are the settings for a clutch, on a 1973 Yamaha CT 175
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $8 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Vintage Enduro Discussions Yamaha DT 175 no clutch 1 1
HOW TO ADJUST CLUTCH ON YAMAHA 175
Yamaha LT100 AT125 CT175 Enduro 1971 1973 factory repair manual on CD eBay
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-dt
Apr 23, 2015 | Yamaha Motorcycles
Clutch or trans is slipping
Hi, Gregg love that first name for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
How to adjust motorcycle clutch cable
13 Clutch Removal yzf600 1996
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
http://www.fzrarchives.com/fzr600/600_manual/1999fzr600r.pdf
Jun 10, 2012 | 1995 Yamaha FZR 600
How to adjust clutch on a 1973 Yamaha ct 175
Hi, Tteliin for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $8 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
DT175 Clutch Adjustment
Yamaha DT175 Manual eBay $8 cheap
1974 Yamaha DT175A Vintage 175cc Enduro Motorcycle OEM Owner 039 Manual... $35
Nov 03, 2011 | Yamaha Motorcycles
Adjust clutch
try ajustin it at cable 1st-up by the lever-thers a fingernut turnit n see if it makes shifting better--if not then follow it to crankcase and inspec there--u may hav to remove cover n fix clutch itself with a manual
Aug 21, 2010 | 1973 Yamaha DT 360
When gasing the engine tranny slips
If you have a manual transmission it is time to replace your clutch. If you have an automatic transmission it is time for a transmission rebuilt. You can have your auto trans fluid and filter changed and this might help, but I doubt it. There is very little you can do for a slipping clutch in a manual tranny except replace the clutch. If you have a manual tranny with a clutch that is manual adjusted then the cluth may be out of adjustment, but I doubt you have a manually adjusted clutch it is more then likely hydralic.
Apr 08, 2010 | 1997 Mercury Sable
How do i install a clutch on a 1990 laser?
You need to get a manual. Try the Haynes manual for your car. Try autozone; generally available for around $20. This is not the type of thing that can be covered here in enought detail to do you any good.
Basics are;
disconect the negative battery cable, set parking brake
locate the trans mounting bolts
get something to support the engine and something to support the trans
seperate the trans from the motor by removing the bolts. On transverse mounted engines you will probably have to pull the trans to get enough room to remove the clutch and you'll probably have to remove the 1/2 shaft axles (front wheel cars) or drive shaft (rear wheel drive cars)
If replacing the entire clutc assembly (pressure plate, flywheel, and clutch), loosen the pressure plate mounting bolts gradually working your way around the pressure plate. If only replacing the clutch then seperate the sperate the pressure plate from the flywheel and remobe. Align clutch with a clutch allignment tools and replace pressure plate. Torque bolts to spec. reconnect the trans to the motor. Few other things to think about. You should replace the throwout bearng when doing a clutch. Lube the clutch fork as directed without getting lub on the clutch face. Hopefully I have convinced yu to get a manual or you will be hating life if you take this on without it.
Feb 21, 2010 | 1990 Plymouth Laser
Zx 2 trans
try having the clutch adjusted and check the fluid under the shifter and the rear end on the axle also.
Feb 04, 2009 | 2001 Ford Escort ZX2
How can i tell what kind of clutch i have?
Your clutch is self adjusting hydraulic design, when the clutch plate gets really worn the adjustment availiable runs out and the trans gets hard to shift, a clutch plate is like a brake shoe, the friction material wears off over time.
Oct 21, 2008 | 1995 Eagle Summit
Clark Forklift Horn Button Switch  , Cat Etc Logo
313 people viewed this question
Top Clark Electrical Supplies Experts
Bill Boyd
Fred Sops
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
