Question about Sewing Machines
Necchi PL1036. Needle bar worked loose and slid down shaft. Right looper struck it and probably bent. After trial and error adjustments, threads will not loop. right looper thread breaks. How to align ? Never was a screw in the threads on top of the right looper shaft.
  • Sewing Machines Master
  • 1,388 Answers
Oh dear..... Bent looper and needle arm loose... Take this to be repaired before you damage the other looper as well and it costs twice as much. Expect looper to be in range of $65 plus service, as a ballpark. There are many variables with overlocker timing and it is beyond the scope of either this forum or the novice to correct the problem I am afraid.
Posted on Sep 08, 2009
Setting a elna 792d for rolled hem
I don't know your model in particular but generally this is how you set up a serger/overlocker to create a rolled hem. Remove the left hand needle and thread if 4 threads are threaded). Now there is usually a lever around the stitching area that you slide back towards you to remove the stitching finger back (disengaged). Then you adjust the top looper tension looser (about 2-3) and lower looper tension tighter (7 or 8). Leave needle tension at normal tension (5). You may need to move the cutting blade to the right too. The technique is to cut the fabric wider but with a narrow stitch so the cut edge rolls under within the stitching. You want the top looper thread really loose so it rolls right around underneath up against the needle thread, the lower looper thread needs to be tight and almost invisible, pulling the upper looper thread down. I usually do a few test runs and check the stitching. Once happy, I turn the stitch length right down to 1 so it is very dense. This uses a lot of thread up.
Ideally use a wooly overlock thread on the upper looper as this "fluffs" out once stitched and "fills" in covering the fabric edge completely.
some good images here
Sewing Basics Narrow Rolled Hems with Serger Sew Mama Sew Outstanding...
Jul 18, 2017 | Elna Sewing Machines
Necchi serger pl1036 hand wheel screw keeps falling out
Try some removable thread locker on the screw. Then retime.
Sep 13, 2012 | Necchi Sewing Machines
Serger - my needles break, never happenned before, and over travels on left upper looper
Make sure, Joe, that your needles are pushed up into needle bar shaft a's high a's they will go. Although same length, the left needle will appear higher than the one on right side when properly seated and tighten clamp screw securely. Check Lower Looper for proper threading--thread delivery eye of lower looper to far left "hidden" from sight. Use looper tweezers and it helps threading it. The thread then gets pulled to right side and goes front to back of that hole in front of you on lower looper. Follow threading guide on the cover door to right of your serger. Hope this helps. Jimmy
Apr 04, 2012 | Sewing Machines
When sewing the thread under the material gets all tangled up. The thread is also tangled in the bobbin. At times the needle doesn't even pick up the bobbin thread, but that is another issue.
have you tried a new needle?
the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
4.also clean under the needle plate for lint & loose threads
check to see if the thread has come off the thread take up lever
Sep 12, 2011 | Necchi Sewing Machines
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Unbalanced lower looper thread wraps aaround the
Loosen the upper tension looper thread by turning the dial to a lower number. The upper tension looper is to tight and pulling the lower looper thread up. Also might want to loosen or tighten the left or right needle tensions depending on the results you get. It will be a trial and error exercise to get the correct adjustment between the loopers and needle thread tensions. Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Oct 02, 2009 | Husqvarna Huskylock Computerized 910
Model 3205 FA not picking up bobbin thread, needle goes down but doesn't pick up bobbin thread, needle not bent, macine was working fine then all of a sudden bobbin thread stopped. Can't even pick it up to...
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
Aug 15, 2009 | Necchi Sewing Machines
My white 2000 serger is dropping the thread on the first needle when I sew with it- the loopers, both upper and lower are working correctly in conjunction with the "right upper" needle. I have changed...
Could be as simple as poor quality thread (not using MaxiLock thread), the needles not inserted properly (the left is slightly higher than the right), a missing stitch forming pin on the needle plate, the needle bar being too high or a looper timing issue.
As the needles raise, the upper looper should move to the right with the right needle tip slightly above the eye of the looper.
Jul 19, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Sewing Machines Logo
234 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
