Hotsync does not connect with device and desktop. who do i recheck set-up? ID#RPN20OU19608570426
4 Suggested Answers
SOURCE: How to HotSync Clie' and Palm Zire
install it on another computer buy her a computer
Posted on Oct 17, 2007
SOURCE: palm z22 usb cable connection problem
Hello Every body,
I had the same problem, and went to the device manager. It said the driver was gone. So to solve this, Just uninstall, and reinstall the software. And it will Sync. at least it did for me.
Hope this helps,
Dakotah
Posted on Aug 13, 2008
SOURCE: I am unable to HotSync and cannot load HotSync manager
I reinstaled the Palm Desktop again it worked....
Posted on Sep 21, 2008
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Can't hotsync replacement t5 ; I dropped my working T5 and have not been able to hot sync my backup unit.
If the new one won't pick up your old files you need to go onto the desktop app and export the data. then create a new id on the new palm. It should now hotsync with the new blank id. Now go back to the desktop and import the files from the other id. Hotsync again and you should have them on your palm.
Mar 19, 2010 | Palm Tungsten T5 Handheld
It won't hotsync, it start to than stops when I get to the what should I do I have a tx
Here are a few things to try:
Check that the HotSync icon in showing in the system tray (bottom right hand side of the screen, next to the time).
Check that USB connections are enabled in HotSync - In HotSync V7.0.2, Right click the hotsync icon in the system tray, Click "Settings...". Click "Connections" on the menu on the left hand side and ensure that the USB option is checked.
Try rebooting your PC and also resetting the device (use a paper clip to reset the device).
You could also try reinstalling Palm Desktop, maybe even remove Palm Desktop, reboot, then reinstall Palm Desktop.
Jul 31, 2009 | Palm Computers & Internet
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
I bought a refurbished Tungsten E. Because there was some incompatibility with the software version of my other Tungsten (which is on its last leg), I downloaded new software off the internet. In the...
Are you syncing the new device to the same username in Palm Desktop as an older device?
If you are, this will cause problems on the new device. When you sync the device, it saves the device settings, 3rd party apps, preferences, etc. in the backup folder in the username folder on the PC. When
you sync the new device it copies the contents of the backup folder for the old device to the new device. This will cause corruption in the settings for the new device thus causing erratic behavior of the new device.
Looks like you may need to hard reset your device and rename your backup folder
Go to http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=887 and follow the directions to do a hard reset. Next before you hotsync your data back over you will need to rename your backup folder, to do that go here;
XP
C:\program files\palm or palm one\[hotsync username]\ and rename your backup
folder to backup.old
Vista
Start-->documents\Palm OS Desktop\[hotsync username]\ and rename your backup
Then hotsync to your current hotsync name and all your contacts, calendar,
tasks, and memos will come back over.
Show file extensions for XP or Vista
XP
If you can not view file extensions on your PC I would like you to open a
folder go to Tools-->Folder Options--> View (tab) and under show hidden
files and folders uncheck hide file extensions for known file types.
Vista
Open control Panel go to Folder Options--> View (tab) and under show hidden
Mar 28, 2009 | Palm Computers & Internet
Sep 20, 2008 | Sony CLIE PEG-TJ37 Handheld
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
HOTSYNC REQUIRES RESET
HotSync menu select Custom, change System to HandHeld overwrites Desktop, set as default. It is probably set to Desktop overwrites Handheld
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
