Question about Maytag MFF2557KES 25 cu. ft. French Door Bottom Freezer Refrigerator w/ Electronic Dual Cool Syste...
My model MFF2557KES refrigerator not getting cold and freezer operating fine.
  • 4,059 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 07, 2009
Fridge not cooling
might need freon or the compressor going out cheaper to get a new or used one
Apr 22, 2012 | Maytag MFF2557KES 25 cu. ft. French Door...
Maytag Model MFF2557KES EVERYTHING FREEZES TOP AND BOTTOM COMPARTMENT
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 17, 2011 | Maytag MFF2557HES Stainless Steel French...
Model msd2651kes Water supply very slow. I can't find any kinks in the lines. Detached hose from back of frig and water just dribbles out. Maybe I hooked up water supply incorrectly when I first...
If when first hooked up the water line if you used a peircing type valve that clamps onto the cold water pipe it clamps on,tighten the screws equally on both sides till its tight around the pipe.Turn that handle in to peirce the pipe in a clockwise motion till it stops,it will peirce the pipe but be in the closed position, so open it in counterclockwise direction till it stops
Gene
Aug 05, 2011 | Maytag MFF2557KES 25 cu. ft. French Door...
I have a Maytag French door bottom freezer Refrigerator. The freezer is working fine but the frigerator stopped cooling entirely. Is there anything that I can do to fix it. A technician will charge $75...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Aug 01, 2011 | Maytag Refrigerators
Frdge not getting cold
Since your unit will have only one compressor, the cooled air must be circulated via a fan that distributes the air between the two compartments and this has probably died. This allows the cooled air to simply fall downward. When you can hear the compressor running, hold your fingers in front of the vents in the refrigerator compartment to see if you can feel any air stream.
Jun 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MFF2557KES 25 cu. ft. French Door Bottom Freezer Refrigerator w/ Electronic Dual Cool Syste... Logo
365 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
