My Samsung HPS5053X plasma TV has sparkles (i.e. colored snow) across the picture and I'm not sure what the cause of it is. I've tried all the inputs and it seems to by on all of them regardless of input. Hockey season is right around the corner... please help!
  • 188 Answers
Realign the voltages for the X-sus and Y-sus/Z-sus panels.If any luck the fault is gone,if not the fault comes from the logik panel wich has to be replaced.
Posted on Sep 07, 2009
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Oct 28, 2008 | Samsung SV5000W VHS VCR
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
I have a samsung plasma tv model# sp-s4223 when you you turn it on the whole screen has sparkling snow over the whole screen trying to find out whats wrong with it
Make sure your t.v. is on channel 3, not the cable box. Use the t.v. remote to change it to the proper t.v. channel.
Apr 16, 2014 | Televison & Video
My samsung tv model hps5053x/xaa is not finding my laptop via hdmi. i have been using it this way and then all of a sudden it isnt recognizing it now. what do i do what is the issue?
have a samsung plasma model HPS5053X/XAA i have it for less" -- because it falls within my area of expertise. I just need a few more details about your situation and I will get to work!
Jan 05, 2011 | Samsung HP-S5053 Television
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
My wife hit the TV button on the Samsung remote and now we can't get the picture bcak on our Samsung Plasma 760 TV. There is snow and sound and we tried going to Channel 3 but that's not working. We tried...
The input may have been changed, press the input button on the remote or tv until you get the picture back.
Let me know if this helps, I can assist further. Please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 22, 2009 | Televison & Video
Static on 50
WHAT COLOR ARE THE SPARKLES? IF RED , BLUE AND GREEN, THEN IT NEEDS TO HAVE THE PANEL VOLTAGES ADJUSTED
Dec 08, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sparkles
Makes you wonder why nobody is taking on the problem, doesn't it?
Well , to the best of my knowledge, it is because nobody really can.
To understand why you have to understand what do they sparkles come from.
They are random electricity discharges coming from capacitors or other components that act like capacitors, but mostly capacitors.
When laymen hear about capacitors they usually associate the word with bulged electrolytic capacitors, which often cause problems in electronics of all kind.
Well this time it isn't about them.
It's about all other capacitors - or other components exposing similar qualities - which are installed on the board. Most of them are small filter capacitors put in parallel to the big ones or to other passive components such as diodes and resistors.
The excessive heat developed by the sustain boards damages those capacitors. It hardens the electrostatic material they are made of and small breaks in it start occurring at voltages that shouldn't otherwise be causing issues.
The trouble is, they can be everywhere. You can't just pinpoint which ones were caught at fault and causing the sparkles.
When it gets REALLY bad eventually the whole capacitor burns and either shorts or, more commonly, just breaks.
Believe it or not I've seen a board that exploded before my very eyes and , after the explosion, started working LIKE A CHARM!
Turned out a small filter capacitor had blown. It as not essential for the board's functionality and after being problematic for so long and causing image deffects it had eventually shorted completely and literally exploded.
Luckily, the short it had created was too short in time and apparently in a circuit that could take the load for a short while without getting damaged.
So after it blew everything worked just great!
it's a real story from my repair experience.
Hope this helps all consumers, DIY enthusiasts and competitors alike :-)
For more you are welcome to visit our site and read our tech repair blog at
http://www.coppelltvrepair.com
and
http://blog.coppelltvrepair.com .
Aug 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
845 people viewed this question
Top Televison & Video Experts
