Question about Singer Sewing Machines
XL 150 embroidery machine. Upper thread keeps fraying and then breaking. I have changed needles(broke many) took out bobbin case and cleaned area. Works for a while and then thread starts breaking again.
  • 1 more comment
  • gzuccarino Sep 07, 2009
    I would be happy to adjust the presser foot tension but I am not sure where that is. I am looking in my manual and cannot find a reference to pressure foot tnesion. Is it one of the bars on the front? Please help
    I went in to the thread meter override. Made the adjustment to loosen the thread and the thread still broke. Was this what you were speaking of or is there something else that is the pressure foot adjuster? Please respond Thank you
    I guess I am not speaking Singerese What is on the left and what is on the right? Are we talking the LCD screen? Or on the sewing machine proper? Detail would help.
    Thank you
    Brigadier General:
  • 3,614 Answers
Adjust the presser foot tension of your unit, this could be the problem why you always break thread.
Hope this helps
Posted on Sep 07, 2009
  • micromaster
    micromaster Sep 07, 2009
    this should be two adjustment the one on the left and one is on the lower right..
  • micromaster
    first check the FF.
    - Needle is in backwards.
    - Machine improperly threaded
    - Tension too tight
    - Needle bent or having blunt point
    - Thread too coarse for size needle
    - Burr on needle hole of presser foot (Caused by breaking needle when pulling fabric from machine)
    - Needle too long for machine, or not inserted all the way in the needle bar
    - Take-up spring bent or broken (Send for adjuster to repair).
    - Tension discs worn so that thread works in groove
    - Needle too fine for size of thread and fabric to be sewn
    - Threads not properly pulled back under presser foot when starting to sew
    - Lint or dirt around bobbin case holder
    - Irregular sewing speed
    To determine whether the upper tension is too tight or too
    loose for the fabric you're wanting to use, try the following
    test.
    the upper tension is too loose. If both
    threads break together and take more force to break, it
    means that the tensions are balanced.
Top thread keeps breaking
Upper thread breaking is usually a sign of incorrect threading or tension too tight, although there are other possible problems:
Industrial Garment Printers Sewing Machines
When threading the upper thread, be sure to ALWAYS RAISE the presser foot so the thread will seat properly in the tension disks. Avoid old thread or bargain bin thread. If the thread is fraying and breaking at or near the needle eye, then try a different type of needle with a larger thread groove that will protect the thread from fraying on rough fabric. Also, check that the thread is not hanging up on something, ie the slit on the side of the spool where the thread tail is stored.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
NMSU Checklist of Common Machine Troubles
Jul 02, 2016 | Brother XL-2600I
Embroidery not working correctly
Well, before I did all that (which may be necessary), I would take a piece of UNWAXED dental floss or hand embroidery floss and floss between the tension disks. You mentioned that you were suddenly breaking threads; there may be lint or loose threads or both seated between the disks, preventing the thread from seating properly. Then,
I would take the embroidery unit off and try to do some sewing with it, to see what results I got. If you can catch and bring the bobbin thread to the top with the top thread, I am doubtful that your timing is off. Sew a line of both straight stitch and zigzag stitches, and see if the stitches are balanced. If not, you may have a bobbin tension issue, and if so, most bobbin cases can be adjusted.
I think you'll find, though, that things will improve considerably when you have cleaned out the upper thread path and tension disks. Make sure when you do that, that your foot is raised, so that the disks are spread. Oh, a drop of sewing machine oil wouldn't hurt either--generally you should put a drop of oil for every 5 hours of embroidery.
Please get back to us to let us know!
Mar 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Futura Quartet embroidery thread breaks
first unthread completely the machine and rethread it checking all the places run smooth. Change the needle for a new one with the correct size for your fabric and project. Clean the bobbin case and surround areas with a brush making sure is neat and no any fluf left behind. Put a fresh feel bobbin and try again. Sure will do the trick and will run perfect again. Happy sewing!!!!!
Dec 11, 2013 | Singer Sewing Machines
I have a Futura XL-400 and when I am embroidering it keeps breaking the thread at the needle area. I hear a noise which sounds like its coming from the bobbin arean then the thread breaks and its also
try these suggestions
change the needle
check the needle plate for burrs
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Apr 11, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
Embroidery Machine
try changing the needle
check for burrs in the needle plate area & on the bobbin case
Mar 11, 2012 | Bernina Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Embroidery thread breaks after about three stitches
I had the same problem....I tried cleaning it just like you did. Eventually, I changed the needle and it took care of the problem :)
Hope that helps!
Nov 30, 2008 | Singer Quantum XL-1000 Computerized Sewing...
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
