Question about Schecter C 1 Plus Electric Guitar Cherry
SChecter c1 plus tuning problems
Hi, i have a schecter c1 plus and it has some tuning problems with the G string. It won't stay in tune . What should i do ? Thank you
  • 916 Answers
If you do a lot of bends or use a whammy bar this will happen a lot. The best way to keep a guitar in tune is to buy a locking system to put on it. I use a floyd locking system for my own guitar.
Posted on Sep 07, 2009
How do i adjust intonation on a peavey predator plus exp?
To adjust the intonation on a guitar you need the following. ..
a electronic tuner
and a small philip screwdriver
when you tune a string say low E you play the note open and adjust tell it's in tune
then to intonate play the low E at the 12th fret
producing a Harmonic, view the tuner it will be sharp or flat,
turn the small philip screw on the bridge adjustment
it only takes a small turn one way or the other so go slow
once the string is tuned at the harmonic note check to see if it's in tune played open, keep tuning and adjusting tell the strings are in tune open and at the 12th fret on all six strings
once intonation is set properly the guitar will sound better
really hope that helps?
Mar 15, 2015 | Peavey Music
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
I have just bought a 1980 Hawk. But i am having trouble tuning it. it is also the pick-ups are really sensitive. It picks up every touch on the guitar. Putting your finger on a string sounds like a drum...
Your guitar Needs to be setup properly, tuning is tough need to wrap strings around tuner peg properly to stay in tune, and the pickups may need to be adjust farther away from the strings?
there are Tons of videos on YouTube showing basic guitar setup,
hope this helps?
Mar 05, 2015 | Music
Tuner Won't Acknowledge Sound
Before turning the unit on, press the calib/batt button to check the battery condition.
The Fender AG6 only responds when the strings pitch is within a certain frequency range. If the guitars tuning is not within that range or if your installing new strings, first connect the guitar to the AG6 with a cord that you know to be in good working condition and turn the AG6 on. Then starting with the low E string (the thickest one), loosen the tuning peg to a point well below the standard tuning for that string. Then slowly tighten the peg as you strike the string repeatedly. When the strings frequency, comes within range you will see the 6E light glow and the needle will begin to deflect. When the needle reaches zero it is in tune. Do the remainder of the strings the same way then go back and recheck each a second time. If you have a tuning fork, you can use it to tune by ear then re-tune and maintain it with the AG6
Remember to always stretch then re-tune new strings several times.
If the AG6 does not respond even after checking the condition of the battery and the cord that connects the guitar to the tuner, the problem could be inside the AG6 with a bad connection on the board. Try moving the cord as you strike a string that you know is close to being in tune. Again a tuning fork would be helpful.
~DrewWatk
Jun 10, 2013 | Fender AG6 Automatic Guitar Tuner
Can't get the guitar tuned
Tell her to tune all strings below the pitch and always go up to the pitch, never down because of slack in the tuning keys. The gears will have a slight bit of play in them. If coming down and stopping at the right place, they will loosen and loose tuning when she lets go. Tuning from below and go up to the pitch will correct that. (more noticeable on electric) Also, I would take it to a shop to have the intonation checked and tuned if necessary.
Dec 25, 2012 | Schecter C-1 Classic Electric Guitar...
How to tune the peavy guitar
well. this may sound retarded but every guitar is the same google or youtube how to tune a guitar, also get yourself a guitar tuner there cheap and affordable
Jun 15, 2011 | Peavey Electronics Peavey Predator Plus...
When i lock the tuning locks the guitar is out of tune within 3-5 minutes of locking, then when i try to re tune it the strings snap. whats the problem?
I am not familiar with your model of guitar, but I assume it has a tremelo system. Usually when a string breaks at the nut like that, it's because the metal piece that locks the string is not smooth, has a burr on it. It could also be that the lock is holding just well enough that when you bend a string it is slipping some but doesn't go back all the way. Try just totally unlocking it and playing a bit to see what happens. The friction may be wearing on the string where it contacts the lock. I am assuming it is breaking near the nut/lock area, is that right? Or is it breaking at the bridge end?
Jan 14, 2011 | Schecter Synyster Standard Electric Guitar
Gibson Les Paul wont stay in tune
That's the problem; you're using light gauge guitar strings. Chances are that if you are not used to playing strings that light, you're fretting hand will hit the strings with more force than is neccesary to fret them, thereby forcing them out of tune. You can solve this problem by adding more winds around the string post (three or more winds should do it), or you can switch to a heavier gauge of string.
If they're true locking tuners, they should have a notch on the back of the gear housing that you turn with a nickel to engage the locking mechanism once tuning has been established.
Also; check the intonation of the guitar itself on an electronic tuner. If it tunes right but sounds out of tune when played, this is an intonation issue, and can be solved by adjusting a small set screw that moves the individual saddle back and forth in the tune-o-matic style bridge. You can check this by tuning the string to the correct note, then playing the same string at the 12th fret and checking it against your tuner. If it rings in true, you're fine, if it comes up flat or sharp, every note on the fretboard is going to be off by that much, and you'll have to adjust accordingly (turn the screw to the right to add length and lower a sharp note, turn the screw to the left to subtract length and raise a flat note, if I remember right).
Hope that helps.
May 12, 2009 | Gibson Music
"G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
LP epiphone 100 "g" string problem,
after tuning ....put a capo on ... if this stops the problem then the cause must either be
1 the string catching in the top nut or
2 a faulty machine head
if it still goes out of tune with the capo on then look at where the ball end of the string sits
Schecter C 1 Plus Electric Guitar Cherry Logo
332 people viewed this question
Top Schecter Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Schecter Music Expert? Answer questions, earn points and help others
