Question about Sony CDP-CX300 CD Player
Sony cdp-cx355 cds skip only on tracks 1 through 5
Hi you might think I am crazy but my Sony CDP-CX355 300 disc changer will skip only on tracks 1 through 5 the rest of the tracks work fine. Once in a while a new cd might work the first time I play it then after that it does the same as the others. I have used a cleaning disc a but it did not help. Do you have any idea what could cause this?
Thanks Colin
  • pdkwingit Oct 06, 2008
    I have the same problem also.. track one plays for about 8 seconds then starts over and repeats.. as you play track 3 , 4, or 5.. then the player will operate correctly. I've tried to clean it, etc. but no luck! The disc does seem to wobble alot when it first begins to play though.
    New Friend:
I got a free one of these from my work...well that is because it was having the same problem and they didn't want to mess with it haha. Sooo...I brought it home..thinking i could just buy a cd cleaner kit and clean the dirty lens..which is what normally causes these problems. To my dismay this didn't work (later found that the lens is a good half inch away from the disc)..so i decided to open the bad boy up (hey I got it for free...no harm crackin it open :-) ) After hitting the lens with a can of air..I tried again...no go. And just so you all know...this player runs vertically..not horizontally. I want to know how does the player read? the lens in stationary. All other players i have seen the lens moves up and down. I'm thinking it might have something to do with that. I gave up on cleaning it and started doing some searches..this was the only forum that was somewhat helpful. I agree with Silverscreen. When i watch the cd's playing the disc wobbles SLIGHTLY up and down. I think the rear stand-alone wheel is a bit too loose. ..The amount it wobbles is hardly noticed but is the only thing i see out of the ordinary.
Posted on Mar 10, 2008
I have the same unit and same problem...This one skips on the first song only. I took the unit apart and looks like the disc spindle is not centered.
Because the laser reads from the center (first song) out (to the last) the disc spins much faster during the songs at the beginning of the disc. As it slows down toward the end songs the skipping is not a problem...
Still working on correcting the problem...although I think I have identified the issue...not sure on how to correct it....new spindle or motor assembly? Where do you get one? Is it worth it to fix or replace?
Posted on Jan 15, 2008
  • 979 Answers
Alignment or dirt (Not in that order) could cause this. It is also possible that the player is not reading the TOC before it begins playback of your discs...accordianman
Posted on Dec 19, 2007
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
Tip
Sony CX355 skipping Fix
I have a Sony 300 disc changer that started randomly skipping tracks after it was 8 or 9 years old.
I tried cleaning it, no change.
I opened it up and found an adjustment screw on the reading lens carriage.
Note: It is very hard to see
It rotates approx 1 turn from stop to stop. It was centered from the factory.
I rotated it counterclockwise 1/2 turn, and it got worse.
I rotated it clockwise 1/2 turn, and it is fixed. It hasn't skipped a beat since.
on Sep 17, 2008 | Sony CDP-CX300 CD Player
HOW DO I FIND THE FREE ONLINE MANUAL SO I CAN PRINT IT
http://esupport.sony.com/US/p/model-home.pl?mdl=CDPCX355&template_id=1®ion_id=1&tab=manuals#/manualsTab Hi this is where I got my manual Reading instructions fixed my problem too
Sep 30, 2012 | Sony MegaStorage CDP-CX355 300-Disc CD...
I need the user manaual for a Sony Mega Storage 300CD
Click Sony Support to download user manual copy for CDP-CX355
If model number is different, let me know to provide you that manual copy.
Thanks.
Nov 04, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
I need an instruction manual on how to use
You can download user manual of CDP-CX355 by clicking Sony Support.
Thanks.
Jan 24, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
Sony CDP-CX300 CD Player Logo
699 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
