Question about Drills
My Clarke 24v cordless impact driver just stopped dead! batteries are fine and charged. Any oppinions?
    Problem Solver:
  • 5 Answers
Have you tried to wipe the contacts on the battery and the Clarke 24 V driver with some 220 sandpaper. There could be some minor corrosion on the contacts sometimes not visible and check
that connectors are actually making contact. If this does not work check your on off switch. This
could be shot.
Posted on Sep 07, 2009
My impact driver doesn't ingage acts like low battery but have charged them,will screw in a screw and then stop instead of going into the impact mode
Likely to be weak battery due to end of life. Test battery voltage with meter right after charge , then again after use then stop. If voltage changes /drops, battery is worn out. If battery has full charge, check the condition of the battery contacts within the driver. Pull out the battery and look inside. The contacts should look bright and shiney. If dark, may need to replace them, but suspect that the switch is also bad. Good luck.
Sep 26, 2011 | Makita 6935FDWDE 14.4 Volt Nimh Cordless...
I have a 24v cordless impact wrench i dont have a charger can i put hot and a ground wirl on it to charge it i
Call Alltrade customer service representatives at 1.800.423.3598. they own Allegheny. have model number (CT 120-C) ready
Jun 05, 2011 | Impact Allegheny 1/2'' Drive 24v Cordless ...
The battery has full charge but the impact wrench will not work i got 26.3 volt on the battery what wrong
Did you but it new? How many batteries do you have? have you had shorter and shorter batteriy life?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 13, 2010 | Impact Allegheny 1/2'' Drive 24v Cordless ...
My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Charging the battery is useless every time!
I HAVE A ALLEGHENY 24 VOLT IMPACT WRENCH THE CHARGING STAND IS BAD HOW CAN I GET ANOTHER ONE OR CAN YOU TELL ME HOW TO CHARG THE BATTERY?
Nov 09, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Battery charger dead & stinkin'
fined the manafectura of Black Max and thay will send you one out ,cheers
Apr 11, 2009 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
224 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
