I have a unit that the capasiter blew apart and one of the motor torque multiplier wires came off i nead to know where it hooks up at ?
    Problem Solver:
  • 11 Answers
The wires for the hard start capacitor run across the run
capacitor terminals.
Hope This Helps;
JSTACH
Posted on Sep 07, 2009
My a/c unit has quit working at home. The Model Number is BRCQ0361BD. When I turn the a/c on, the unit will hum, but the fan won't come on. Sometimes IF the fan does come on, it only stays on for a few...
Sounds like you need to replace your evaporator blower motor capasiter, it is located on the houseing of your blower motor, easy to do , but be carfull, they hold a charge and can shock you.
remove the two wires and replace like for like, check operation. If problem still exists, you need to replace the blower motor.
This should help.
Jun 29, 2011 | Heating & Cooling
All trans to engine bolts are removed. engine mounts are free, engine still won't come out. I don't know what else could possibly be keeping it from seperating. Is it absolutely necessary to remove...
YES YOU MUST SEPERATE TO GET TO FLYWHEEL
THER IS TWO DOWEL PIN ONE PER SIDE TOWADS THE TOP OF THE TRANSMISION
PART OF ENGINE BLOCK THEY OFTEN BIT AND HOLD ON GOOD IF YOU ARE SURE THAT
ALL THE BOLTS OF THE TRANSMISION ARE UNDONE YOU SHOULD PUT THE ENGINE MOUNT BOLT BACK IN PUT JACK UNDER FRONT OF ENGINE HARMONIQUE PULLEY TO
STABILIZED MOTOR THEN WITH SECOND JACK AT REAR OF TRANSMISION JACK UP TO
START THE RELEASE THEN LOWER BACK DOWN TO RELASE TOP OF TRANSMISION
THEN WITH SUTIBLE PRY BAR BETWEEN ENGINE AND TRANS PRY APART UNTIL FREE
FIRST I WOULD UNBOLT TORQUE AND PUSH BACK IN TRANSMISION AND PUT A RETAINER TO PREVENT TORQUE FROM FALLING OUT OTHERWISE YOU WILL NEED TO CHANGE THE TORQUE PUMP INPUT SEAL IT WILL LEAK IF SEPERATED
May 26, 2011 | Ford Expedition Cars & Trucks
My unit keeps fluxuatng between cold air, then warmer air. It will start cooling then the unit seems to dim then amp back up sending out non cooled air.
Your compressor is drawing locked rotor amps. If the unit dims and then turns off a few seconds later, your compressor is going out on the internal thermal overloads. It could be a bad start capasiter or bad winding in the compressor. If you don't know electricity, it is not something I would recomend a DIY to fix.
Sep 28, 2010 | Amcor PLM-14000E Portable Air Conditioner
We have a jenn air outdoor cooktop. The right side didnt work so we took apart and blew circut breaker. Now we are trying to re wire but dont know where the green ( ground) connects. Canyou please help?
Hi, depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire..
Take care
May 01, 2010 | Jenn-Air JED8230 Electric Cooktop
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
I have a Kenmore special edition model # 110.63912100 (S/N ML350387S) that will not heat. What do you suggest, heating element, thermostat, or ???
first make sure you have 240 going to the dryer.you will nead a meter check this.if you have 240 ,than you nead to unplug unit.pull unit out and take back panal off.on the right side you will see the heating colom.at the top is one of the high limit switch's.you will nead a continueaty meter to check this.at the bottom you will see the other high limit switch.make sure you unplug wire's before you check them.under thst you will see the heating element.remove wire's and check out element.also look for bad wiring.if all check good, you nead to call for service call.
Nov 16, 2009 | Kenmore 62802 Electric Dryer
How to hook up a motor torque multiplier where the wires co to the capasiter
I guess you mean where do the wires go FROM the torque capacitor. They go to the terminals on the RUN capacitor. if you have 3 terminals on the run CAP. connect them to HER. & COM.
I Hope This Helps. If Not Get Back With Me. We Can Work It Out.
JSTACH
Sep 07, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
