Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
46H84 Shorting out/No replacement bulbs available?
The green CRT bulb on my 46H84 is shorting out and my repairman said the parts are not available. Is this true? If not true, where can I buy them?
  • Tennis2D Sep 07, 2009
    Thanks so much, you've been very helpful. I appreciate your expertise!
  • Tennis2D Sep 18, 2009
    The part numbers for the 46H84 Toshiba given by Rylee Smith turned out to be wrong. I needed a CRT bulb, not a DLP Lamp
    Correct part no. should be 23078430.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The lamp is available, you can buy the lamp & other parts for your toshiba tv from this link--
Toshiba 46H84 Lamp & Other Parts
Toshiba 46H84 Parts List & Parts Number
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2009
I have Zenith rear projection TV Model IQC60H95W.The blue tube does not work. The red and green project. Is this a bulb or tube and are they available to purchase? The TV was made in 2001
This is a CRT(cathode ray tube) not a bulb. A Bulb is totally different. If you replace one Tube, you need to replace all 3 or the colors will never match properly. However, This model no longer has parts available. Even if they were, the cost would be close to $1000 in parts. I would not recommend repairing this TV.
Sep 14, 2014 | Zenith Televison & Video
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
Replacement bulbs
Probably through Mitsubishi only.
Are you sure you want to pay the cost of the CRT'S?
These are the Part Numbers for each of them.
RED CRT --------251C217040
GREEN CRT----251C217050
BLUE CRT-------251C217060
Mitsubishi's Parts Deparment 1800-553-7278
Nov 16, 2009 | Mitsubishi WS-65411 65" Rear Projection...
I have a Toshiba 46H84 with a now defective Green bulb or tube. TV shop said government regulations won't allow them to fix it. Any possible fix?
I would be looking for a different shop and send them the bill.
If all fails go on ebay and get a new bulb and find someone who can replace it.
I wouldn't suggest you do it yourself because of the voltage these televisions put out.
Oct 23, 2009 | Toshiba 46H84 46" Rear Projection...
Green CRT Bulb is shorting out on 46H84 Toshiba. Repairman says no replacement bulbs are available.
Thanks I ordered the part # required to solve the problem through the links you provided.
Sep 07, 2009 | Toshiba 46H84 46" Rear Projection...
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Coolant leaked from the green bulb
Yes, the diagnosis was correct. Some models of Mitsubishi as well as a few other manufacturers have had issues with this. The cost to replace circuit board damaged by the coolant (ethylene glycol) along with the affected CRT is prohibitive. Check with Mitsubishi. Some manufacturers acknowledge problems such as this and may offer assistance.
Feb 13, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Toshiba 46h84 rear projection shutting down
I have a Toshiba 46h84 with similar problem that needs a new green crt. Mine does not have a cooling fan. I don't know if having a cooling fan would help the problem, but mine didn't come with one. There are rear projection TV's that have bulbs in them that require a fan. This particular model uses a red, a green, and a blue crt to generate the picture and probably doesn't need one.
May 19, 2008 | Toshiba 46H84 46" Rear Projection...
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
784 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
