Question about Cell Phones
The port where you plug in the charger seems to be loose. It is not falling out, but when you plug in the charger, it will not begin to charge unless you apply constant pressure pushing it toward the back of the phone. The charger does not sit snugly in there either.
  • 328 Answers
Charger plug is broken from main board and needs to be taken apart and hopefully it can be resoldered.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 07, 2009
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
Tip
Why your phone won't charge
<span>Hello,<br /><br />there are three or more reason why your your phone won't charge;<br /><br />1. The charger might be defective.<br />2. The charging port of the phone might be defective.<br />3. The battery cell might be very weak or the battery might be defective.<br /><br />Charger<br /><br />A defective charge can cause a phone not to charge. To actually find out if your charger is defective or not, borrow a charger from a family or friend that has the type of your phone, use the borrowed charger to on your phone. If the the phone charges, then obviously, your charger is defective and need to be replaced. It is also good to test your charger on another phone to confirm the status of the charger.<br /><br />Make sure you run the above test, before buying another charger so that you don't waste your money. Sometimes, charger might be working and phone won't charge due to some other reasons that would be discussed below. So confirm first before buying another charge. Don't buy another charged based on assumptions........<br /><br />Battery<br /><br />A battery that is very flat, I mean a battery that its cell is very weak, won't charge with a phone charger. You might have to leave the battery in the phone with the charge plugged in for some minutes or hours before the battery will begin to charge and other times, it might not charge at all.<br /><br />What make batteries to be in this kind of condition is; <br /><br />1. If you use you phone to the point when it says "low battery" and you still don't charge the battery and the phone turns off by itself. This can run down a battery cell.<br />2. If you leave a battery in the phone idle for a days or months, the battery cell will become weak. Or if you leave a battery used for days or months.<br />3. If you don't use the correct/right charger for your phone, this can drain the battery instead of charging it.<br /><br />Batteries in such condition will have to be fast charged with a desktop charger. The desktop charger will be connected directly to the battery and the battery will definitely pick up within 1 hour. Thereafter, you can continue charging it with your phone charger and it will charge immediately.<br /><br />But if the battery is defective, it won't charge at all. Even if you use a desktop charger. Such batteries needs to be replaced. Also, it is good to test the phone with another battery, and charge it to confirm before buying another battery.<br /><br />Below is a picture of what a desktop charger looks like;<br /><br /><img src="walesarumi_4.jpg" /><img src="walesarumi_3.jpg" /><br /><br />Charging port<br /><br />If non of the above seems to be the reason why your phone won't charger, then it means the charging port is defective. <br /><br />Most times defective charging port confuses people. They think the charger is the reason why their phone won't charge and after using another charger on their phone they still find out that the does still does not charge.<br /><br />Once your phone doesn't charge, the first this you test is the charger and second, the battery. But if the battery and charger seems not to be the cause of the problem, then it is the charging port that is cause the problem.<br /><br />Your charging port might not be defective, maybe it loosed contact with the phone phone or it shifted from it's position. Sometimes, the way we forcefully insert our charger into the phone can make the charging port loose contact.<br /><br />At this point, you will have to disassemble your phone. But if you feel it is a task you cannot perform yourself, then take the phone to a repairman to help you out. But if you feel you can do it yourself (DIY), read further.<br /><br />Turn off the phone. Remove the battery. After that, get a phone screw driver, unscrew all the phone screws, remove the phone cover in order to gain access to the phone panel and get to the charging port. <br /><br />Check if the charging port actually loosed contact. If it didn't loose contact, then you will have to replace the charging port. <br /><br />Note that some charging port are soldered to the phone board and some are not. So if yours is not soldered, simply remove the charging port and make a replacement. But if is soldered, you will be needing a rework station. Rework station is what you will use to remove the charging port.<br /><br />Below is a picture of what the rework station looks like;<br /><br /><img src="walesarumi_5.jpg" /> <img src="walesarumi_6.jpg" /><br /><br />I hope the above makes sense to you.......<br /><br />Good luck.<br /></span>
on Mar 23, 2011 | Cell Phones
I have a 1.5 amp charger for my bike it was dropped but now it shows its hooked up backwards and will not charge any help?
The fall caused a component inside to become loose or shorted, the only thing you can do is replace it.
Feb 06, 2016 | Schumacher Electric Speed Charge...
Medion lifetab will not power up
get it repaired, contact manufacturer
Feb 04, 2015 | Tablets & eReaders
Can not charge
The socket that the charger plugs into has come loose from the control board. The only thing you can do is open it and resolder or send it in for repairs.
Jan 20, 2014 | Trust Flex Design Tablet
Hp g60 laptop needs a charger port replacement
I had the same issue with a toshiba. I opened up the laptop and put a cut piece of wood that fit behind the connection. that prevented it from falling out when the charger was connected. tape will help hold things in place.
Mar 10, 2013 | Computers & Internet
Problem with charger headset port. it became loose.
ok im having the same problem, im thinking of getting a new charger and or buying a new charging connector for the phone (where the charger/headphones plug into. You can get them on ebay for about $4 US.<br /> hope that helps?
Jun 22, 2010 | Sony Ericsson P1 Cellular Phone
Charging port lg chocolate
wow to soder the charger port for lg vx8500
charles
Feb 18, 2010 | LG CHOCOLATE VX8500 Cellular Phone
My charge port in my 2006 cadillac cts repeatedly blows the fuse. How can I fix this?
Does the fuse blow every time you plug something into it? I guess what I'm getting at is it possibly your phone charger only, or does the fuse blow when someone else plugs thier charger in (different charger)? I guess if the fuse blows, no matter what you plug into it, I would suspect the charge port itself. Does it seem like it's loose in it's mounting bracket? You may have to replace the port.
Jan 03, 2010 | 1995 Cadillac DeVille
Motorola Razor V3 wont charge
Your Charger Port On Your Phone May Be Loose or Begining To Have A Break in The Wire, Seek A Phone Technician If You Do Not Have An Advanced Understanding Of Phone Circutry
May 11, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
177 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
