Dell POWER SUPPLY Power Supply
Problem for Dell POWER SUPPLY Power Supply
Dell xps 710 will not start
By sstewart04 on Sep 07, 2009
dell xps 710 will not start when it has been on. When it is turned off for 2 or 3 hours it will start
Best Solution
posted on Sep 07, 2009
Very Helpful)
bob_computer
Rank: Guru  Dell Expert
Rating: 87%, 1244 votes
I am pretty sure this is not a power supply issue.
There is a very strong chance it is an OVERHEAT issue
My first step being the easiest would be to take off the side of the computer after disconnecting it to check for dust build up in and around the cooling fan and power supply.
This is easily fixed with a can of compressed air meant for cleaning computers and just requires that you take it outside and blow it all out whilst wearing glasses and without poking the nozzle into anything.
Ram slot problems are quite rare nowadays but it may not harm to just remove it and blow out the slots and then put it back in.
Check that any extra cards are also seated fully as this can happen esp. if the computer was moved or leads were pulled that connect to them.
Computer are designed nowadays to shut themselves down if there is a problem.
What you should do is check the fan assembly and if it is loose at all that would give good reason to do what I am going to advise.
Disconnect the fan from the board.
Check your manual for the exact instructions but you should remove the cooler completely
DO NOT REMOVE THE CPU
Now with nothing more than isopropynol and cotton bud sticks or another alcohol based cleaner remove the old thermal grease / sticker from the top of the CPU (make sure it is clean)
At this point it is up to you but you could consider a newer better cooler
You could take your old cooler to a good computer shop show them it and just ask for a better one
If you are using your original cooler then here we go
Do the same with the underside of the cooler.
While the cooler is off it may be worth giving it a good 8low job
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business.
Another consideration is that many cases have places in them for extra fans and usually extra connections on the motherboard too.
They are quick and easy to fit.
Quite often I will fit TWO in what is called a push/pull configuration. One pulls cool air in while the other pushes hot air out
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dell POWER SUPPLY Power Supply
Questions and Unsolved Problems for Dell POWER SUPPLY Power Supply
Do you recommend Dell POWER SUPPLY Power Supply?
Answer
Answer
How to refill a lexmark 26 colour cartridge
Answer
On T5048,photo thumbnails open very slowly and are only half-size
Answer
the image it is not working no power is not working
Answer
I have a Dell L733r. It has a wire from power supply that says P2. My new power supply does not have... (More)
Answer
When I double left mouse click on drive D: or drive H: it doesn't open it. In order to open the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top System Power... Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
