Question about Dell Inspiron 1501 Notebook
Dell inspiron problem reformatted hd installed fresh copy of vista when rebooted will not reboot.went to screen one time boot from cd to fix problem but it does not recognise cd drive
  • 558 Answers
As it boots hit F2 and enter the bios,there on the left hand side you should see an option for maintenance,select thatoption to default your computer.You may also try removing the power ,the memory,press and hold the power button down for twenty seconds.Once that is done reinstall all.Also remove the disk you have in the drive check for scratches make sure its clean use alchol to clean then try again.
Good Luck
Posted on Sep 08, 2009
Dell 1525 dont maneger is dosent see in the screen how i reformat
Reformatting the hard drive of a computer is sometimes an unavoidable task. Whether you're an IT professional or a private user, there are times when the hard drive has to be totally wiped. These reasons range from reallocating a computer to another user, selling it or donating it, installing a larger internal hard drive or even just to eradicate some flaky behavior. Unless the computer is ancient, reformatting a Dell laptop is a moderately easy process.
1. reformat-dell-laptop-1.1-800x800.jpg Damaged hard drive is a reason to reformat
Back up any data on the PC that you plan on saving. This can be accomplished by using burnable CDs or DVDs, attaching an external hard drive, using an online backup process or hooking up to the corporate backup server.
  • 2 reformat-dell-laptop-1.2-800x800.jpg Older flavors of Windows include a bootable floppy Set the boot order on the laptop. This tells the computer the order that it looks for a bootable disc. The default is the C: drive, but this can be changed by holding down the Delete key while booting the computer. If you're using a floppy, which is common with early versions of Windows, select the A: drive. If you're using the CD or DVD, then select that drive (usually the D: drive) by using the up and down arrow keys. Save your preference and exit.
  • 3 reformat-dell-laptop-1.3-800x800.jpg A software restore CD Insert the media (floppy or CD/DVD) into the computer, and then reboot. Select reformat and install, which will erase all the data on the drive and install a fresh copy of Windows.
  • 4 reformat-dell-laptop-1.4-800x800.jpg 2.5-inch internal hard drive Keep an eye on the process, as earlier versions of Windows often require manual intervention such as selecting options, or pressing the Enter key at certain times. More recent versions of Windows are typically autorun.
  • 5 reformat-dell-laptop-1.5-800x800.jpg Disk image utility Follow the prompts during the installation and after rebooting it. Use the restore CD to install any additional drivers and utilities. Run the Windows updates, and if you're planning on keeping the computer (or assigning it to another user), then install any necessary applications and data files, and configure the preferences, email and printers.
  • I hope you find it very helpful. Thank you for using fixya.
    Aug 15, 2011 | Dell Inspiron 1525 Laptop
    Dell inspiron 1545 slipped from bed.Windows black screen is seen and not able to boot, display is stuck at "windows is loading files".Is it a software or hardware problem, what to do?
    Probably hardware.. but try to detached and attached the memory and HD of your laptop maybe it got loose or something. if it did not work reboot then choose safe mode. else reboot the use installation cd to boot your computer.
    Jun 12, 2011 | Computers & Internet
    I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
    All you've got to do is:
    1) Insert the new hard drive.
    2) Press the F8 key as the laptop boots. This will take you into the BIOS.
    3) Locate the disk drive priority setting in the bios.
    4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
    5) Save settings and exit the BIOS. This should reboot your laptop.
    6) Insert the Windows XP CD.
    7) It should not start the setup as it recognises the CD.
    8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
    9) After the format it will reboot your system.
    10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
    11) Now it should start the install. Follow the on-screen instructions.
    Mar 15, 2011 | Dell Inspiron E1505 Notebook
    Installed new HD into Dell 1720 Inspiron after getting the 0146 errr code. Once I installed the HD I began the installation of Vista. It almost finished then the screen went back with the cursor...
    you need to format the hdd first before you can successfully install Vista.
    try booting from cd/dvd by pressing F12 on the Dell screen.
    - Select optical disk drive dvd/cdrw and press Enter
    - Press Any key to boot from CD or keep tapping the spacebar.
    - If you see Windows Setup EMS enbaled, press Enter.
    - Keep clicking next until you are asked "Where do you want to install windows?"
    - Click Drive options Advance
    - Click or select to highlight the partition to where you want to install Vista
    - on that same windows, click "Delete" and OK
    - Click "NEW" and then click "Apply"
    - Click "Format" and then "OK"
    - After that, you may now click "Next"
    Now windows vista should be installed in your computer and on its last boot, it will ask you to create a profile (username and password).
    ^_^
    Jun 12, 2010 | Dell Inspiron 1720 17" Widescreen...
    Toshiba Satellite Vista 32bit...Big start up Problems!
    1. you could use the vista to reformat the drive.
    2. you could use boot disk to do the same thing.
    or
    3. load again the vista for fresh installation.
    Apr 08, 2010 | Toshiba Satellite A130 A135 Notebook
    Start menu issue
    If a system restore does not take care of this issue, then i recommend backing up all data then reinstalling the operating system. If you need further assistance, you can contact us 24/7 at 800-595-3564. Thank you.
    Jan 18, 2010 | Dell Inspiron E1505 Notebook
    Virus removal complete now cannot reboot
    Well you would either need to do a system recovery, using the "Ctrl + F10" shortcut at the dell bios splash screen when you first turn on your machine, or you will have to call Dell and have them send you another copy of your OS (this may cost you some money, so be prepared.) Then reinstall using the disk.
    Oct 04, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
    Dell inspiron 1420 startup error
    You need to cheat a little. First try to boot into safe mode by pressing the f8 key as soon as you hit the power (and keeping your fingers crossed on the other hand that it notices your doing this). Before you get too depressed just try booting into safe mode and then reboot normally. That may be all it take to fix it. Try this a few times before getting into the more serious fixes.
    If you can get into safe mode you can simply copy your files off to a usb data drive. Those will still work. You may be able to use the wired network card if you select safe mode with network access. But don't count on that. The cd/dvd will not work so you can't burn it to disk. A flash drive will work on the usb while a external hard drive that connect via usb usually won't as it needs drivers.
    The other way is to boot using a bootable cd. If you can get a vista install cd you can install over the top of your existing windows and retain your settings. If you don't know where everything is then you need to be a bit creative and use something like the demo Ubuntu cd that boots into a windows like operating system that will allow you to copy stuff over the network to the usb drive or the network.
    If you have a friend with the right laptop or desktop you can take the drive out and set it up as a second drive. When they boot normally they then can see your drive and just copy burn or move your stuff. This is what I do in the shop when the existing system is too messed up to work with. There may be the odd thing you won't get access to but you should get most of it.
    Jul 09, 2009 | Dell Inspiron 1420 Laptop
    Can you please assist me how to install XP or any OS in hp laptop which has os windows vista?
    1) You must have a Bootable O/S CD/DVD
    2) You will have to do a clean installation of O/S
    If installing Win XP be sure that there are Drivers for the Laptop available for Win XP. If not some of your hardware will not function properly.
    Jan 07, 2009 | Computers & Internet
    Dell Inspiron 1501 Notebook Logo
    Alun Cox
