Question about Garden
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
  • 388 Answers
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Posted on Sep 08, 2009
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
STRING KEEPS BREAKING ON A TROY BILT WEED EATER TB539E
Take a look at the hole in the spool where the business end of the string comes through. There should be a smooth metal grommet or smooth short tube there. If the metal is missing, then the string is breaking because it rubs against plastic and heats up very quickly. Or the tube or grommet might have a rough or sharp spot. You might be able to polish it up with a Dremmel type of tool.
Sep 01, 2010 | Troy Bilt Tb70ss Gas Trimmer
My Troy-Bilt line trimmer model no. TB539E Line trimmer disintergrated while using it. My problem is finding and ordering replcement parts and if necessary how to install them.
Several small engine dealers have parts for Troy Bilt but here is one site that will give you your part numbers and an idea of the costs you are looking at. Good luck!
http://www.ereplacementparts.com/
Aug 17, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Weed eater runs slower
Your air filter may be plugged, your pug may be fouled, or your carb may be gummed up.
Sep 10, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Blade on my weed eater troy build
I would suggest that you obtain a blade that fits. Reducing the mount will be dangurace
Jan 26, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
1,255 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
