Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Leaking all over the floor
Every time I do a load water leaks out to front of the bottom of the washer
  • 1 more comment
  • RKV003 Dec 11, 2007
    Is there a secret to removing the pump? I think that's where my leak is but am timid about breaking something. Other than the clips, what is holding the pump on the motor?
  • sara_n_ator Dec 22, 2007
    When the washer is filling (not emptying) during the wash or rinse cycle, water leaks out of the bottom of the machine. Probably 2 cups of water total. Help!
  • Anonymous Jan 25, 2008
    I'm having large amounts of water that is leaking from the bottom of my washing machine. Not sure if it's during the wash or rinse cycle.
  • 51 Answers
Remove the two screws that hold the consul on and flip it back. remove the two gold color spring clips under the consul and lean the cabinet forward to take the cabinet off. Your problem can be spotted easily now. Check your pump, it's on the front of the motor. Check the outer tub for a cut or hole. Look on top of the transmission for a seal leak.
Posted on Dec 09, 2007
Easy fix, do the above and replace the white plastic pump! about a $22 fix!
Posted on Apr 03, 2008
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Water is leaking on to floor checked all
Does the machine have a filter that needs cleaning at the bottom front of macine
Jun 06, 2009 | Roper RAX4232KQ Top Load Washer
Water leaking out of the bottom
Sounds like the main bearing has gone bad and that is causing you to loose water on the floor. There is also a rear seal back there that will need to be replaced
May 22, 2009 | GE WSXH208A Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Water Leaking on floor.
probably the water dispenser valve.
Apr 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal De
