Question about HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all-in-one
After installing genuine XP professional (the program I had for more than 3 years turned out to be forfeited; however, the subject printer worked quite well) my all-in-one decided to quit working. It makes a whirring sound as if pulling paper in but nothing happens thereafter except a window on the PC screen pops up to indicate there is no paper in the tray which is full of it. Please help!
Pararelo
When installing hp psc all in one 1210 it says the file cannot be accessed by the system, when i check the system requirements check plug in it states that the OS is not supported although the it installed...
From the manufacturer's web-site:
http://support.hp.com
enter 'PSC1210' and search.
Select the latest device-driver for your hardware and for your Operating System. Download it, and install it.
Jun 12, 2010 | HP PSC 1210 All-In-One InkJet Printer
I dont have a cd to install hp psc 1210 all in one
do not worry sir here is the link where you can download the program and install if for your psc 1210 printer. Once you open the link select the correct model from the list and then select the operating system and start the download once completed start installting and do make sure the printer is connected to the computer and it shoudl be turned on.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=+PSC+1210
Feb 25, 2010 | HP PSC 1210 All-In-One InkJet Printer
Printer installer not compatible with the OS. i need one compatible to windows vista. HP psc 1210 all-in-one
You download to the internet for the driver with the window vista compatible installer.. Just type HP psc 1210 driver download then click search. Select and click the website that have an available program for that printer.
Oct 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have the hp psc 1210 printer but when I tried to install the software on my HP Pavilion I was told it was incompatible
You should not connect the unit until after you load the disk. Look under the add/remove programs and see if there is a program you can uninstall, then reinstall. Try the HP website for a driver too. What are you using, Windows XP?
Aug 02, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 Printer
just chek ur black catridge is working or not just try to clean it and install
Oct 19, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer
send me dirver software hp 1210 all in one inkjet printer
Jan 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
PC power resets w/ HP PSC 1210 plugged in
one of these updates causes a conflict more than likely a microsoft hotfix, try using a different usb port and unplug and plug printer back in
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Can't install to Vista HP PSC 1210
Use Paint.
It's not ideal, but I can scan with my HP PSC 1205 running Vista when I use Paint. Just click 'file' then 'from Scanner or Camera'.
Works a treat.
Sep 23, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
