Model ls-k2463hl runs as soon as power is turned on at circuit breaker fan speed goes up and down
  • 534 Answers
You possibly have a motor that the windings are bad. These windings swell when power flows through them and in turn the swelling presses onto the shaft causing the problem. Also, I would replace the capacitor first in the event it is bad If the motor runs properly then that capacitor is the only problem. If it doesn't cure the fan problem then the motor is going out. If you change the motor the capacitor will also need to be changed anyway so try changing capacitor first. Good Luck hope I helped you some
Dave
Posted on Sep 16, 2009
Have 1959 Westinghouse table fan wit Leviton switch missing power cord. Need help rewiring power cord
120v?? Neutral stays neutral, hot goes through the switch and then your ground. Three easy steps, IF you turn the power off;)
Jul 18, 2017 | Heating & Cooling
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Replaced a circuit breaker on our heat pump our air goes off right but the blower stays on what could be wrong
The blower relay (called a fan relay) is stuck and must be replaced.
Want to do it your self? Trace the two power leads from the blower motor. usually white and black for high speed, White and red medium.
(Blue,purple and brown are capacitor colors)the white wire goes to the line side of the contactor. the black or red wire goes to the fan relay. This arrangement allows the blower to continue running for a minute after shut down to dry the cooling coils or complete the heating cycle. (Line side is where the incoming power wires connect)
Aug 28, 2014 | Ruud 2 Ton Split System Heat Pump
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall...
pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
Oct 12, 2013 | Craftmade International CQ52 Ceiling Fan
My rooftop a/c unit makes a compressor noise as soon I as plug in my travel trailer. It's a 2009 Outback Sydney edition 310 bhs with a dometic a/c unit I believe. basically with the thermometer switch to...
The system blows cold air when turned to on position but also makes that sound between cycles
NOTE THE ON / AUTO SWITCH BETWEEN GREEN,FAN AND YELLOW ,COOL TERMINALS ON THE THERMOSTAT,
THE FAN SWITCH NORMALLY CLOSED GOES TO LOW, HEAT SPEED, WHILE THE NORMALLY OPEN GOES TO THE HIGH SPEED, COLING SPEED.
BY TURNING FAN ON NOTHING BUT FAN SHOULD RUN..
SWITCHING THE BREAKER TO OFF PRECLUDES THE UNIT FROM DOING ANYTHING !
WHAT CAN IT DO WITH NO POWER!
I switch the breaker to the off position when not using the a/c in order to keep this cycle from occurring. A
Sep 16, 2013 | Dometic Rooftop RV Air Conditioner
I have a speed queen sc35md2yu40001washer that keeps blowing the 2amp fuse as soon as I switch on the breaker it is the fuse where the incoming power goes through before it goes to the transformer
Good job tracing the location of the fuses. Now, logically, the transformer is the next thing to check. When power is turned off at the house breaker, remove one of the wires on the output side of the transformer and see what happens when you turn the power back on. If the fuse blows, the transformer is shot and needs to be replaced. If not, go to the next device on the circuit, etc...
Jan 16, 2013 | Washing Machines
My Sole f83 will not start. initially Fans run, can raise/lower. will act noemal until motor should run/doesn't. then raise/lower function stops. If I try to use speed buttons LS light shows. moto
LUBE or wax the deck belt, this happen because you do not have schedule maintenance according with the owner manual. The machine shut down for autoprotection in electronic system Do it NOW.
2) LUBe the rollers bearint too with WD-40 only for rollers
3) Test the drive belt motor, for worn or cracking belt, replace or adjust it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubelshooting help.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 15, 2012 | NRS Sole F83 Treadmill
I have a Samsung Ductless Air Conditioner. It wil...
i think there is a short circuit in the fan or compressor even in the board.loop check it & say how many amper is there?
May 21, 2010 | Samsung AS18A6RB Air Conditioner
Only fans work on split system model ls-k2463hl earth breaker trips when compresor tries to start I own a Panasonic Heat pump model A18CKP6G with the same problem. The compressor was replaced last June...
Sounds like a wiring problem between the outdoor unit and the house. You would be surprised what I have come across in 30+ years of A/C work.
But it could also be the compressor.
I will need to know answers to the following -
Does the compressor have a soft start (2 wire capacitor looking device that attaches to the run capacitor), hard start (relay and capacitor), or just the run capacitor?
Were the run capacitors and start components replaced when the compressor was replaced?
Is the breaker a GFI breaker, or just a standard breaker?
Rain or humidity is not usually a factor, but it may be something.
Reply back what you find.
Feb 01, 2009 | Heating & Cooling
Does the compressor try to start and the shuts off or is the breaker slamming off as soon as it is turned on. If it takes a few seconds the comp could be locked up and trying to start, high amps and tripping breaker. Tripping breaker right now would indicate a shorted or grounded compressor. Really would need to be ohmed out with a meter to check for ground. Not good either way.
Apr 25, 2008 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
