Question about Watches
I have a EYKI japanese watch and i need to remove some links can you help me please
5 Suggested Answers
SOURCE: Remove links from metal watch band
This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
I used a neoprene mouse mat as a work surface, which was ideal as it allows the pin to move out, whilst supporting the links and stopping any slippage. I also rigged a table lamp close by.
There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
Posted on Oct 01, 2008
escapement
  • 2334 Answers
SOURCE: i need to remove watch links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
slp11508
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
escapement
  • 2334 Answers
SOURCE: Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Posted on Apr 08, 2010
I need to know the battery number for this timex elec.dynabeat please
Timex Ref Renata Energizer Varta Japanese I.E.C. US & Ind.Std A 9 BSR44L 521 SR44SW SR44 I hope this chart helps you out! I would go with the energizer BSR44L
Sep 07, 2015 | Timex Watches
How can I get the invicta model 2144 manual
Follow this link:http://www.invictawatch.com/ Hover over the COLLECTIONS tab and click on INSTRUCTION MANUAL. There you will see RONDA and MIYOTA movement tabs. Those are two manufacturers of watch movements used to produce all INVICTA watches. RONDA is Swiss company and MIYOTA is Japanese. Check out both to find an exact match to your particular watch.Unfortunately that is all Invicta can offer. Rate me please.
Feb 27, 2011 | Invicta Lupah 2144 Wrist Watch
Apr 08, 2010 | Swiss Stauer Deep Dive Watch
I am about to buy tag heuer link calibre 36 limited edition 1996/2000 and is got these numbers at the base cn111b.ba0337 and a signature and a japanese name is this watch original? thanks
Fake Tags are common! The only surefire way to tell if its real is by the movement! They use Swiss ETA movements. Fakes use Japanese movements! If you are purchasing this watch online...well good luck! If you can take it to a watch repair company then I would suggest that before you buy so they can open the case back and see what kind of movement is in it! A real Tag will cost upwards of $1500 plus and I would think a Limited Edition would be even more!
Jan 09, 2010 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
How do i remove a link from the watch band?
hi friend,
step 1
Measure the watch band's length. Every wrist size is different, and there's no need to remove all of the links when you may only need to remove one or two. Putting the watch around your wrist and pinching each link around it to see how much room you need gives the jewelry wearer a reasonable estimate.
  • Step 258782_65x95_aspect.jpg Open the watch near the link you want to remove. Link watches have several openings, so even if you open the wrong clasp, it can always be reattached.
  • Step 358783_65x95_aspect.jpg Flick the tip of your fingernail inside the clasp to open the extra links. Continue doing so until you have removed all of the links that are too big for your wrist. If you have short fingernails, try using tweezers or anything with a sharp edge that can easily unfasten a link. New watches tend to be very stiff, so it may take a little nudging, but the links come off. It will be obvious which ones come off and which ones don't by looking at the back of the watch band. The links that come off have a claw on the tip of each one and sometimes have the brand name on top of it.
  • Step 458784_65x95_aspect.jpg Put the extra links in a safe place. There may come a time that you either let someone else borrow the watch or your wrist swells and you need these links again.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If you can't get the links to open, visit a jewelry repair store. Workers there may be willing to help you adjust your watch for free. If you bought the watch from a retail store, the jewelry counter is usually required to adjust your watch for no additional cost.
    hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Kenneth Cole Reaction KC3367 Wrist Watch...
    Need instructions on how to adjust G7710 G shock watch as my manual is in japanese would like to adjust overseas times as it seems to be in japanese setting
    Here is the link to find the manual in English:
    http://world.casio.com/wat/download/en/manual/
    Do not forget to rate, please.
    Mar 07, 2009 | Casio Watches
    Remove links from fossil metal band
    Jan 09, 2009 | Fossil Arkitekt watch
    Watches Logo
    318 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
