Question about Cell Phones
I have a t-mobil flip phone. the up and down scroll button want do up. how do I get the cover off to reset the rubber ?
Motorola factory reset
First click on settings Next click on Security Now scroll down and click on Restore Now A window will pop up asking you if you want to permanently erase all user data and reset settings to factory defaults, click yes. It will then clear the phone to pre-purchase condition.
Mark
Motorola Support
May 02, 2014 | Motorola Mobility Crush W835 Black Rubber...
Tip
How to Reset your Samsung Phone If You Can't Access It
  • Turn Off Your Phone
  • Now press and hold together: Volume Up + Home + Power button, until you see Samsung logo.
  • After a bit you will have access to the phone's boot menu. Using the volume up/down buttons to navigate, and the power button to make selections, find and select the Wipe Data/Factory Reset option.
  • Scroll down to Yes, delete all user data, and press the power button once again. You will notice script scrolling along the bottom of the screen, which will end in Data Wipe Complete.
  • Once the operation is complete, press the power button once more to reset the device.
http://www.digitaltrends.com/mobile/how-to-factory-reset-galaxy-s6
on Jul 08, 2016 | Samsung Cell Phones
Reset a motorola bp6x
Hi Anonymous
please follow the next steps to make a hard Reset your device : 1. remove the battery cover remove the battery and put it back again
2. press and Hold the R & M key and press and press and hold the power button until you see the android image with the exclamation mark, then release the buttons
3. Press and hold in the middle of the he volume up and volume down key,
4.it will show up a menu then you need to select the 3 option wipe cache and factory Reset selected with the volume down, confirm with the power button, scroll all down until you see the option yes , then press the power where is reboot system now, and that will reset your device.
Regards
Maya
Motorola Support
Apr 15, 2014 | Motorola Mobility CLIQ XT (2 GB) Cell...
Zte x501 locked forgot passcode
You're going to have to do a hard reset...THIS WILL ERASE EVERYTHING ON THE PHONE (not the sd card)
Make sure the phone is off, hold the power button, volume down and the back button (third button from the left on the bottom) AT THE SAME TIME, hold and wait, once your in the back menu use the volume button to scroll down to factory reset use the power button to select, use the power button again to scroll down to yes, and power button to select, just wait, with will shut down and turn itself back on, takes about 5 minutes to restore function. (I worked for Cricket for a long time and I know the phone well)
Sep 01, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
X501 completely shuts down during calls then restarts and says "preparing SD Card" and continues giving error notifications
Aug 13, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
I forgot my zte groove password
Apr 22, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
I need to reset a mytouch phone
Hold down the power button, and your volume down at the same time. follow prompts
Jun 12, 2012 | T-Mobile HTC MyTouch 3G Slide...
Can i stop the alcatel one touch 665 from playing a tone when i open and close the clamshell
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Nov 20, 2011 | Cell Phones
Perform a hard reset on Motorola C139 from Tracfone
Master Reset
  1. From the standby screen, press the Menu key.
  2. Scroll to and select Settings.
  3. Scroll to and select Other Settings.
  4. Scroll to and select Initial Setup.
  5. Scroll to and select Master Reset.
  6. Enter the Security Code, press OK. NOTE: The default security code is 1234.
But... it doesnt sound like this will help your problem as i have a feeling that you have a logic board issue and even if you get it to work its going to do it again... and again... and your not the only one.... is quite common fault Do Not Choose Motorala would be a good recomendation for your next phone! maybe LG or Huawei...
May 08, 2017 | Motorola Mobility i355 Cellular Phone
I need reset pin number
To reset your pin on your base station, you push Menu, scroll to System Settings, DON'T PUSH SELECT, push * 6 5 # That will reset the pin.
Aug 17, 2007 | Siemens Gigaset 8825 Cordless Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
