Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate 1tb external hd just beeps
I have a seagate ext 1tb hard drive i have tripped over the wire and knocked it over and now it only beeps every few seconds and no light on the front and is not recognised by any of my computers xp or vista
  • 3,153 Answers
You may want to open the drive and check the internal connections first to make sure none came loose after you have powered it down.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
If a drive is CLICKING after an accident there is a very strong possibility that it is dead or dying. This is known as the "click of death".
Posted on Sep 07, 2009
Mine did the same,, £150 down the pan as it happened after warranty. Even more funny, when I complained they said I should back up my data, funnily enough, the 'Maxtor secure storage motto' with shock protection etc led me to believe it would be a great backup device. All it took was a child to pull the wire and I lost it all.
Obviously Maxtor is behind nearly every other external hard drive manufacturer when it comes to flash/capacitor buffering.
I am defiitely not using Maxtor/seagate again, this was a shockingly poor piece of hardware.
When I finally managed to get the casing open i tested the harddrive, and it will not even be picked up by windows so I can format it.
Posted on Nov 12, 2009
My iomega external hard drive just beeps when ever i turn it on. How can I fix this?
ummm, i fixed my problem i had with a iomega 500gb external hard drive, it was beeping at me also, so what i did was i knocked it on its side, switched it off, by its own panel, then switched it back on, it came back into life and was recognised again!!
so try it with yours!
I think what what happens is, when you accidentally drop it, or knock it from time time(accidentally), the needle inside the hard drive goes out of place, and the hard drive will beep, or something to that effect. knocking the case itself again, might fix the problem, or maybe not, thats if the hard drive itself is more severely/inherentally faulty.
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My external hard drive is not being seen by my computer?
1 of 2 things can be wrong...1 (cable may be loose) unplug the cable (ext HD) connected to pc, now reinsert back into pc..try this once or twice...until you see it appear in my computer....if this is not working and your ext HD came with a CD software..uninstall (make sure ext HD is not connected) software, then reinstall make sure your firewall allows it to be connected....this should do the trick...now plug HD back up to pc...do not format your ext hd unless you really really dont want the data on it (format erases everything)
May 27, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
I have a seagate 1tb external hard drive. i knock it off my table and it landed cables down. Unfortunatly it push the usb connection in the hard drive in and it cam apart. I opened up the drive and it...
You can try soldering it back, but it may still not work. If your soldering skills are not great, you should probably let someone who does that kind of work for a living try the repairs. Give me a call if you need to.
Jan 07, 2010 | Seagate FreeAgent Pro 1TB External USB...
When I enable TurboUSB, it turns off my ext hd
yes..that is predictable..most externals can not take the boost without a firmware update. check the buffalo site for a driver
Dec 05, 2009 | Buffalo Technology 1TB DriveStation...
I am having a problem with my seagate freeagaent Desk 1tb ext hdd
Sounds like the Partition table has become corrupt.
Try some of the free tools from here:
http://www.freedownloadmanager.org/downloads/rescue_ntfs_partition_software/
Hopefully one of them will be able to repair the partition table on the drive and allow rescue. If not download a trial of Ontrack Easyrecovery Professional and run a scan firstly for damaged NTFS/FAT volumes and if that fails perform a RAW recovery of the filetypes you require.
Jul 23, 2009 | Computers & Internet
Seagate freeagent 1TB Ext HDD wont power up.
try with removing and reconnecting the bus cable and smps cable.
and try with different bus connection
Jul 13, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard Drive Buzzing and Wont work (Seagate External Freeagent 1TB)
You are in trouble!
The buzzing sound is the heads trying to realign themselves at the beginning of the platter.
You could try putting it on a side and hope gravity helps.
But i'm afraid its broke beyond repair.
May 13, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
1tb hard drive with 2 500gb hd's which i need to separate
Use a third party tool to split the drive. Drive image has that capability.
Nov 12, 2008 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
2,075 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
