Question about Nokia N79 Cellular Phone
I'm usually activating my (N79) camera from stand-by, by sliding open the lens cover. From time to time the program crashes with the message "system error" and in order to use it again, I need to restart the phone. Why do you think this is? Can I do anything about it myself or should I take it to service?
  • 83 Answers
Try updating the Symbian OS by using your PC suite's software updater. If you have transferred lots of file on the attached memory card, try reinserting the card and let the phone read the contents before operating it. If problem now persist after this, you might be having hardware problem.
Posted on Sep 07, 2009
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Shutter is not opening in PL-90
A stuck automatic lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it:
METHOD 1:
Point the camera straight down into a vacuum hose (while the vacuum is on) and tap it around the insides. This will help to **** the dirt out instead of pushing it in further like compressed air might do.Also turn the camera on and off constantly while doing this.
METHOD 2:
1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible.
2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degrees to clear out any debris that may be in there.
3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work then it may be necessary to open the lens barrel to access the lens cover mechanism.The lens cover mechanism is usually accessible for many cameras without needing to open up the camera case.
May 31, 2011 | Samsung PL90 Digital Camera
Its message "Leens Cover Closed" What
Some pocket point and shoot cameras have a sliding lens cover which needs to be opened before the camera is turned on. Olympus is great for that and they are great ideas but you need to slide this cover open.
Dec 11, 2010 | Cameras
System error
This error usually comes due to faulty sliding mechanism.Put a bit of force on the focusing lens to push it back into camera casing. That's the reason the sliding mechanism won't work. The lens is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.
Or else try out this method
Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Thank you !!
Jun 19, 2010 | Nikon Coolpix 4300 Digital Camera
Lens Cover Error-Lens Cover will not open
You may have dust or some liquid blocking the cap from opening. Take a q t tip and clean cap. Use the q t tip to try to jar cap loose.
Jun 30, 2009 | Nikon COOLPIX S51 Digital Camera
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Camera powers up but lens cover fails to open
It could be some grit or sand causing the lens cover to not open, so the camera won't initialize. Try cutting a slip of paper narrow enough to slide between the lens opening frame and the lens cover. Move it in and out to clear any grit that might cause the spring-loaded cover to bind. Good luck !
Dec 14, 2006 | Sony Cyber-Shot DSC-P41 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Lens will not retract
In my case, there was dust in the switches that sense the cover movement.
  1. Close the sliding door and wait until the lens is drown inside (timeout).
  2. Open the screws that secure the front cover.
  3. Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
  4. Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
  5. The sliding door rails and the movement sensors are now visible. Clean all dirt.
  6. Try the door functionality.
  7. Mount the front cover after the lens works as it should. Close the screws.
  8. Mount the sliding door.
May 27, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Nokia N79 Cellular Phone Logo
113 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
