Question about Olympus P-440 Thermal Photo Printer
White lines in on my prints
I am having an issue with white lines (2) on the LH side of my 8x10 prints. I thought it could be dust and have taken the unit apart and cleaned it to no avail.
    Master:
    Sergeant:
  • 460 Answers
Your printer catridge has been faulty.so pls replace it.
Posted on Sep 07, 2009
Print unable 30 error
The print unable is an error caused by build up of dust on the encoder strip. Unfortunately there is no easy way to reach the encoder strip to clean it without taking the machine apart and putting the machine back together after you take it apart is not easy.
Paying to repair the unit is a little over priced and not usually worth it. On the bright side, Brother's new line up of ink jet machines allows easy access to the encoder strip to clean it without hassle.
Thanks,
Pat
May 11, 2010 | Brother MFC-5860CN InkJet Printer
Gestetner DSC 232SP: I purchased this copier used and it had printing ok. My color copies are coming out horrible. they are displaying a white line in the same area on page after page. Even after I ran a...
The white line or lines are NOT caused by the fuser. A defect "line" in the fuser would cause the symtom of the print rubbing off the page but not blank lines on your copy. First we need to separate your copy quality issues. This machine uses 4 drums, 4 developer units and a transfer belt. Most copy quality issues will reside in 1 or more of these units. Lets start with a few questions. 1)Are your copy quality issues ONLY on color copies? or are the black and whites poor too? 2) Are you running copies only thru the document feeder or have you made any copies from the glass?
Are you printing on the copier from your computer?
Dec 04, 2009 | Gestetner DSc232sp Copier
Dell 3000cn has vertical white lines on
Copied from the Dell community forums:
This is from a previous post and may help with your problem. I have printed 1000's since I came up with this fix with no recurrence of any streaking. Let me know how this works for you. I have come up with the cause and a fix for the above problem. This also fixes the problem of lines running the direction of paper travel on color prints. Black and white prints are OK. If you have a warranty on your printer or drum unit then you can have the drum unit replaced and hope you get a good replacement drum unit. To fix your drum unit do the following: 1. Remove the drum unit from your 3100cn. 2. Set the drum unit on a clean level surface and avoid touching the drum or the transfer belt (the decal with 4 arrows points to the transfer belt). 3. Remove the 6 screws from the top cover (the cover has the blue handle attached). Two screws are on top at both ends of the blue handle. The next 2 screws are on the sides and line up with the decal with 4 arrows. The last 2 screws are also on the sides and at the lower corners of the big decal that shows how to remove the drum unit from the 3100cn. 4. Carefully lift the cover from the drum unit and cover the drum unit with clean paper to protect the transfer belt from bright light. You can carefully reinstall the drum unit without the top cover and run some color prints. If the lines are gone then continue with step 5. 5. Look at the ribbed side of the top cover. Some may show some toner build-up. Some of the rib intersections are too high and are dragging in the toner that is applied to the transfer belt. The ribs are there to add stiffness to the cover and to keep it from bowing. 6. Place the cover handle side down on a clean towel. 7. Using a palm sander with 320 grit sandpaper and light pressure (the weight of the palm sander) sand until the ribs going both directions are showing signs of being sanded. You will be able to see the difference as unsanded areas will be glossy and sanded areas will have a dull finish. 8. Switch to 600 grit paper and do a light sanding. 9. Wash the cover under cool water. Don't use hot water since that could cause the cover to bend. 10. Dry completely. I used compressed air. 11. Reinstall the cover to the drum unit. Tighten the 4 side screws first and then the 2 top screws last. 12. Put the drum unit back into the 3100cn and try a color print. 13. Please post if you have any questions about the procedure. 14. If your next drum unit has the same problem you can swap top covers.
Message Edited by Ron13863 on 09-04-2007 07:16 AM
Nov 16, 2009 | Dell 3000cn Color Laser Printer
The Print has white stripes
White stripes are caused by dust and toner powder on the scanner window, which is situated in the bottom of the printer, under the drum unit. Open the printer, remove the drum unit and using a soft cloth with a little meths wipe the window clean of toner and dust. It's quite dark inside the printer, so use a torch to find the glass panel (only about 10mm deep x the width of the drum).
Jun 24, 2009 | Brother MFC 9180 All-In-One Laser Printer
Hp 6210 won't print or read anything that goes through top feeder
The scanner unit is not coming to the home position for the ADF, you can't get individual parts.
Mar 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Lines on Paper
Under the drum there is a thin ****-glass. Make sure there is nothing on the glass. Do not use compressed air to remove the debris from the glass. Use a dust cloth or such. Using air will blow the debris into the laser unit and it will have to be taken apart to be cleaned.
Jun 02, 2008 | Brother MFC 6800 All-In-One Laser Printer
Removal of border on bottom and right side of 8X10 print of color slide.
well this could be caused by a couple of things that i know about.
1: there is a line of dirton the drum, which may need to be cleaned to clear it.
2: there is a shadow set up when it prints now.
May 30, 2008 | Epson RX620 All-In-One InkJet Photo...
Olympus P-440 Thermal Photo Printer Logo
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
