I have a leak in the back of the washer, the machine is approx. 12 years old, it is a maytag, i have tried to run water through the hoses to check for the leak but they dont seem to be leaking but nthe hoses are as old as the machine. it appears to be leaking below the hookups
    President:
  • 1,776 Answers
Check for a defective and leaking pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller spins freely. If any blades are broken/missing or if you can't get the impeller to spin freely, the pump is defective. Hopefully it is just something clogging the pump or the impeller is jammed. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 07, 2009
Leak
You have 3 areas to check. Drain hose, water pump and hot/cold water valves. Any of those 3 areas can be the cause. Most often leaks are caused by loose hoses, but neptunes use a plastic water pump that can clog and lose bearing water seals as well. Try the easy options first, then if those solutions don't point to the cause, remove the front cover and check the water pump for moisture.
Mar 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
17 year old maytag washing machine leaking water under washer towards the right front.
The pump is at the right front. When the seal goes bad the pump will leak down the shaft. Check the hoses too.
Feb 02, 2010 | Maytag Washing Machines
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Washing machine is leaking from bottom of machine
Wow, this washer is very old. im sure the drainage hoses will need to be inspected or replaced asap. i would also check the pump housing for cracks as well. make sure the water inlet valve assembly ins in good condition as well. Replace any hose or valve that is leaking or, damaged.
Jun 05, 2009 | Maytag Washing Machines
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Maytag Dependable Care LAT9206
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
