Question about Epson Stylus CX6400 All-In-One InkJet Printer
I got a new printer then loaded the paper in and was doing a test print. The paper came out and then it returned inside the machine. I tried to pull it out when the paper ripped leaving a piece inside the machine. I am unable to reach that piece of paper.
    Master:
    Sergeant:
  • 460 Answers
This paper will inside the printer. if you can open the printer then remove it otherwise you can checked it from printer shop.
Posted on Sep 07, 2009
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
Why do my pictures have lines across them?
Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Canon PIXMA Office Equipment & Supplies
I have an HP 4515 that is printing blank pages. I have tried to replace the toner and the power supply board. Neither resolved the issue. When the paper gets deliver out the paper is warm. This occurs when...
I believe I understand your issue:-
The printer is able to come to ready- your still able to navigate the menus. the printer goes through all the motions of printing except producing an image-
Having the machine print a test page ( internal Print ) tests whether the formatter is still able to generate a digital image ready for the print engine, but does not diagnose the print engine-
1) power down and remove power cord
2)remove the toner cartridge, use a pair of pliers and gently rotate the drum ( within the toner cartridge, a drive gear/mesh can be found on the end of the toner unit)- are you able to turn this drum or has it seized?
if it doesnt replace the new toner with another NEW toner and try again
3) return the power and power up the machine having first disconnected all network connections.
allow the machine to come to ready.
4) ask the printer for a config page ( internal print) and estimate when the paper is immediately below the drum surface ( toner cart) and using the power switch turn the printer off- causing a jam in the centre of the printer - this is ok we do this to see if an image has been generated on the drum surface- remove the toner cartridge and slide the drum protector plate to the side, look carefully at the drum suface ( you should see a latent image of a config page, at this point look at the paper still jammed inside the printer and see if there are any signs of toner ( there should be part of an image allready on the surface ) now if there is an image on the drum but no image on the paper then I would replace the transfer roller and or transfer HVT power unit, if however there is no image on the drum then you have a very serious problem which will require a new laser unit ( but this should really come up with a diagnostic error code)or Primary HVT unit.
Feb 06, 2014 | HP P4515n LaserJet Printer
Hl4040cn will not print test page
Try doing a machine self test to ensure that it is working properly.
Press OK/return to "Machine Info"
Then down arrow once to "Test Print" and OK/Return.
The machine should produce a self test printout. If the machine does not give a print out, try cleaning the paper pick up rollers at the back of the paper tray cavity. Be careful, the machine is heavy.
If a full test print happens - Your printer is working fine and the problem is at the computer end.
It's possible driver installion is faulty or incomplete and you should try re-installing the printer driver. Is it also possible that your printer paper settings are either incorrect or do not match the paper in the printer. Check and match your paper settings in the printer preferences and the paper tray.
Jan 02, 2013 | Brother HL4040CN Laser Printer
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
MY PAPER IS JAM IN MY HP DESKJET D4160 PRINTER
Open the paper jam cover at the back of the printer and remove the jammed papers, be sure you return properly the cover afterwards. Re-start your machine.
Mar 02, 2009 | HP DeskJet 3745 Printer
Copystar 1635 copier/printer set up problem
What the problem sounds like is that the machine and print driver are set to diifferent paper types.
One says plain paper and the other bond paper.
Or something like that, the machine says bond and the printer plain paper.
Chech the size setting and paper orinentation.
Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached.
Feb 12, 2008 | Office Equipment & Supplies
Received faxes with not print
Stop playing with it, Return it and exchange it. You have a year warranty.
Dec 28, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
Epson Stylus CX6400 All-In-One InkJet Printer Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
