The coffee brews fine but the steam wand is not working. I just cleaned it and water comes through the wand in a good stream and it steamed. A couple of hours after cleaning, the steam wand has stopped steaming again.
When I got my X1 (used,) the steamer was clogged. I unscrewed the end of the nozzle, and a big chunk of calcium(?) came out. I had to poke it with some wire with the steamer on. The way I got the end off is: I wrapped it with a leather glove first, then turned it with a pair of pliers. I still managed to scratch it a little bit though. Maybe you can turn it by inserting a needle in the little hole on the side of the nozzle. I've been thinking of using distilled water to avoid the calcium build-up in the future.
Had the same problem and removed the end of the nozzle... But now I can't get the end back on again.. It does not appear to have a screw thread on the end of the nozzle, and if I just jam it on, it flies off when I turn on the steam... My ideas on how to get it to 'stick' ?
PLEASE NOTE that drinking distilled water for more than a couple days will remove all minerals from your body, resulting in illness and/or death! Distilled water IS good to drink as a detoxifier but it should be drank in combination with regular water and only for a few days. You should take a multivitamin to help replenish the nutrients it will strip from the body.
Pressure build ok.
exactly as described - steamer wand not working althought everything else appears to be ok.
my ascaso trio has stopped steaming
