Question about Canon PIXMA MP160 All-In-One InkJet Printer
E mail received hotel booking,confirmed will have to present copy when needed, tried to print, only printed header but nothing else! what is wrong?
2 minutes ago I accidentally booked the wrong dates for hotel booking.
contact the bookings number in the confirmation email or phone the hotel direct.
Jun 05, 2017 | The Computers & Internet
I made a reservation at a hotel in Provo Utah. I need to change the date. How do I do that?
You can make use of Expedia and apparently not suffer fees related to changes or cancellations. I suspect other sites might have similar arrangements, such as Hotels.com or Bookings.com or other such booking sites. I would certainly be printing out confirmations of any changes. Bear in mind that rates may vary dependent upon a variety of factors, travel packages, contacting travel agencies, etc.. Quotes vary for the same hotel.
Alternatively:
Call and ask to speak to the reservations clerk or party in charge of reservations. Enquire about any fees related to such a change in order to avoid any surprises. Bear in mind that cost vary from day to day and that you are unlikely to know about whether some convention might be booking around the same time, flexibility many be limited. Ask for confirmation of any changes via email. Print out any changes made and take that with you, just in case of any glitch in processing.
Jun 03, 2017 | The Computers & Internet
Confirmation of booked hotel
On a rare occasion, a reservation may be missing from a hotel system. To email the hotel requesting confirmation, printing out the confirmation, and keeping it with you is a good precaution to resolve this exceedingly rare event. And it might clarify if you booked at another hotel by mistake.
Jun 01, 2017 | Computers & Internet
Printer won't print bod of e-mail after printing only header info
Try to highlight it and then print. It sometimes help with me.
Oct 02, 2017 | Yahoo Mail
Cant print text but prints headers, footers and pictures
try to make a copy ...if success
try to disconnect the power cable from the back of the printer and reconnect it after 20 seconds
try to print from the notepad ...............if success great
or else
uninstall the printer from the computer and reinstall the printer as a fresh
it should work and it has worked in most of the issues ................. thank you
HAMID
Oct 20, 2009 | HP DeskJet F4280 All In One Printer InkJet
BLANK PAPER
If you receive a fax with blank pages , nine times out of 10 the answer is that the sender fed one or more of the sheets into the fax machine upside down or backward. You can confirm that this is what happened by noting whether the header (lines of sender information) is present.
You could also be experiencing a technical or mechanical problem, such as a need to fix or change parts. You can test whether your machine can print at all by using its “copy” function, or print an activity report. If all is well on your end, the problem must be with the sender’s machine.
If, by any chance, you’re using an old thermal fax machine, check to see if the roll of paper has been put in backward, because if that’s the case the heads won’t print on the side that isn’t heat-sensitive.
Thanks for using Fixya.
Apr 16, 2009 | Office Equipment & Supplies
Print Preview in Yahoo mail not working in Firefox
Try uninstalling Firefox and download a new package and reinstall Firefox again.
Also,,will your print preview settings work in IE ?
If they dont work in either browser then it may be your printer driver.
Jan 27, 2009 | Compaq Presario Notebook
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
22 people viewed this question
old marine
old marine
