Question about Garden
My leaf blower starts up fine but when I advance choke to its 3rd setting which is all the way open and try to raise throtle it dies out and have to close choke to keep running.
    Novelist:
  • 133 Answers
Sounds like a carb issue. Try spraying carb and choke cleaner while it is running. If that does not help may be remove carb and clean and rebuild it. My weed eater does same thing and I get it running and then spray it down. It takes a couple of sprayings but it helps.
Good luck
roundo4
Posted on Sep 07, 2009
  • 474 Answers
If its a two stroke motor first check your air clnr. If its ok then your carb probably needs adjusting. There is usually two scews.1 has a L " low" the other has a H "high" beside it. Get it running at an idle and turn the L slowly in or out which ever make it run better .slowly start moving the choke to the run position with every adjustment.do this until it runs with the choke fully off.
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
How do I keep my Yardman bp2 leaf blower running? will idle but not come off of choke.
It sounds like a carb problem. You can buy a rebuild kit on line for cheap and rebuild it.Should run fine then.
Oct 11, 2014 | Garden
Yardman 27cc 445cfm Backpack Blower starts fine, but when I try to depress the trigger for more power it dies. Idles smooth with full choke and dies when on no choke setting. Have had someone say it needs...
There may be a plugged fuel filter in the fuel tank, or perhaps you have the oil mix to rich. other problems could be that it needs a new spark plug or carburetor adjusted.
Try spraying the carb out with carb cleaner, add a little seafoam in with the gas.
Oct 21, 2013 | Mtd Products TB2BP EC 27Cc Backpack Blower
Weedeater 25 cc gas leaf blower-only run on full choke and raise back up and it ies.Any solutions??
The raising or reving back up before it dies is a sign of fuel starvation. Check the diaphram in the carburator.
Mar 06, 2012 | Homelite 'Yard Broom' Leaf Blower
Poulan bv200. will not throtle up. it starts with choke at1/2 and throtle at 1/2. new spark plug and clean air filter. when i try to zero choke it dies. and at full throtle it will not get to full speed...
The unit is lean. rebuild the carb with a carb kit and check your fuel lines. If they are brown or discolored or brittle they need to be replaced. carb kits run approx. 11 - 18 dollars from your local dealer.
Nov 23, 2009 | Poulan Garden
THE ENGINE RUNS FINE FOR 10 SECONDS THEN KIND OF DIES OUT BUT WILL THEN RUN FINE FOR 10 SECONDS AND THEN DIE OUT
Try replacing the in-line fuel filter, the Air Filter and Spark Plugs. Also make sure that you are using the proper start up procedure. In many cases that means using the highest choke setting until the engine tries to start, then going to the next choke setting and so forth until you get to no choke. It is imperative that you let engine run for at least 5 minutes before use to warm up. This will ensure a longer life and consistent running.
Oct 06, 2009 | Homelite Consumer Products Backpack...
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
I am trying to start my homelite leaf blower but i dont have the starting instruction sticker that came on it. the sticker had all the steps on how to adjust the two valves, throtle and choke. so if...
Hello ben_brumett:
On My Homelite Blower I Simply Set the Throttle Lock. Pull Out the Choke (on the other I Move a Lever) and Turn on the Switch. Now Pull Until it Starts or Attempts to Start. Remove the Choke and Allow it to Warm Up for 2 or 3 Minutes.
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
Apr 17, 2009 | Homelite 'Yard Broom' Leaf Blower
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Garden Logo
696 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
