Question about Canon PowerShot A400 Digital Camera
My camera was working fine and then it gently rolled on to the rug and then it never worked right since. I got the code in the corner of the display E18 and I cannot do a darn thing with the camera now. Should I just chuck it ? ??? Its a cannon power shot A400. (When I turn it on the display light comes on and it beeps numberous times and then the E18 signal comes on and then it goes away and the camera turns off. I do not even think the shutter opens up ) The batteries are charged so what now. Your assistance would be greatly appreciated. Thank you for taking time out to read this. J. Hartel
CompuGuy44
  • 432 Answers
SOURCE: CANNON A520 POWER SHOT DIGITAL CAMERA
Tab on the camera. E18 is a stuck lens. This is common on this camera. I'm not saying this will fix it, but don't break it.
Posted on Jul 04, 2007
Bubbabear64
  • 2794 Answers
SOURCE: 6 beeps, something strange on LCD, won't take photos
I'm sure 6 beeps means something but with the Canon makes their manuals they never tell you what it means.
Here is the complete owners manual for the product in case you don't have one:
http://gdlp01.c-wss.com/gds/0900001188/PSA540_530CUGad-EN.pdf
The troubleshooting section starts on pg 89.
If that section doesn't help you, Best Buy may have a solution or any camera in your area can help you.
Posted on Jun 29, 2008
t00nz
  • 4738 Answers
SOURCE: E18 Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. If there's any consolation, the A400 lens barrel is very resilient in its design, so there is some hope here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 13, 2009
  • 11 Answers
SOURCE: Cannon Power Shot A80 with error code E18
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
If none of this works for you please comment.
Good Luck!
Stay Classy
B.
Posted on Mar 29, 2009
t00nz
  • 4738 Answers
SOURCE: i have a cannon powershot a 85 it was working
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jun 23, 2009
My panasonic canister vacuum agitator brush does not spin when on
Possible that you did not get the belt on properly and came off right away.
Apr 13, 2014 | Panasonic MC-CG917 Canister Vacuum Cleaner
Rolling screen
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different remote controls are also included. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Dec 10, 2012 | Zenith Z32LZ5R 32 in. HD-Ready LCD...
Unknown error code
if heater runs then you get that heater is overheating if not working need new display board
Jun 11, 2012 | Jandy Digital Lite2 Lj250 Btu Heater,...
On the lcd it shows "E" "E 9" and I do not know what this means and the camera will not work. What needs to be done
This question has been answered repeatedly. Pentax error codes are mostly for camera repair technician diagnosis and most of the time mean the camera is broken and needs professional servicing. Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can appear when the film is inserted incorrectly, when the batteries are changed in the middle of a roll of film, if you are using defective film, etc. If "E" appears in your camera's information display, try to rewind your film manually (see your user's guide for instructions on how to activate your mid-roll rewind function), and try a different roll. If this problem keeps occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom lens.
H0-H9: These H codes can also identify a problem with your camera's shutter.
U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
Sep 22, 2009 | Pentax Zoom 105-R Film Camera
Have a kodack c330 camera
That means that you can delete the picture right away if you do not like it. Also it can be that your memory card if full or not working properly.
May 16, 2009 | Kodak EasyShare C330 Digital Camera
Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
Sony DCR-HC20 displays E 61:10 in upper right corner, no zoom
I can simulate this fault E61:10 by pulling out the CCD ribbon cables. This is an error that is pointed to no signal from Camera CCD assembly. Very gently remove the screws for the LCD cover assembly and remove. If you look in the upper left corner you will notice a ribbon cable connection. There is one more connection that should be checked, and it is located in the top portion below the CCD assembly. Make sure that all ribbon cables are currently attached firmly. Take specail care in opening your camera.
Jan 05, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
New screen
yes a new LCD might fix this issue.but it could also be a bad display circuit.
Mar 11, 2008 | Canon PowerShot A450 Digital Camera
Flash doesnt work
There is a small battery (or large capacitor) inside your camera that stores a charge for when the flash fires. If you dropped your camera and hit the right spot, this battery may have been bumped out of position. A solution would be to open up your camera to see, but this is obviously risky and can void a warranty if you still have one. If you do choose to look inside, be sure to not tear any gentle wiring as this can ruin your camera for good (I know because it's happened to me).
Jul 13, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Problem with Shutter/Lenz
This sounds like a stuck shutter. There is a delicate assembly inside your lens that will block the light right when you snap the picture allowing the image sensor to record what it saw at that very moment. This shutter is composed of two blades that come from either side of the field of view and overlap to completely block the light. It sounds like what has happened to your camera is that one of those blades has either come off its guide or has become stuck. The shutter assemblies in these cameras seem to be very delicate and sensitive to even minor impact. Due to the anti-shake features it will have to be returned to the manufacturer for service if you want to get it fixed. David Millier Advance Camera Repair
Sep 01, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
Canon PowerShot A400 Digital Camera Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
