Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
The brother printer mfc-240c says that please wait and then it starts beeping and again plzz wait. What is the problem. What should i do
  • 77 Answers
Please push the menu button, then start mono, then 4x arrow up. Display should be ||maintenance|| and printer should beep. What error code does the display show up?
You have to open the scanner as if you were changing the cartridge. There is a "-----;-" cover which hides the flatcable. Remove this cover and reinsert the flat cable to the mainboard by simply sticking it into position. May or may not work, it may have wiggled loose.
Posted on Sep 07, 2009
How do i clear the memory in my brother 240c fax/printer machine
Press menu*2864 within 3 seconds. the screen will show "maintenance". now pres 01 and it will initialise. Press 55 and wait for maintenance again. now press 99 to exit back to date and time.
the machine will have cleared all its memory and returned back to default.
May 31, 2011 | Brother MFC 240C All-In-One InkJet Printer
Using Windows 7, Trying to install printer, Brother MFC-240C. When computer starts or restarts Small window reads: Failed to start the ControlCenter. The required registry information is missing. Please...
After doing a bit of reading, it seems the Brother MFC-240C model is discontinued. I didn't see any support for windows 7, so what we can try is changing the compatibility.
1) Uninstal the suite/drivers, then restart your computer.
2) Reinstall the suite/drivers and restart your computer once again.
3)Look for BrCtrCen.exe in the directory of where ever the suite is installed.
Should be either
C:\Program Files (x86)\Brother\ControlCenter3\BrCtrCen.exe (for 65 bit windows)
C:\Program Files\Brother\ControlCenter3\BrCtrCen.exe (For 32 bit windows)
4) Right click BrCtrCen.exe, go to compatibility options and set the compatibility to vista.
Information source:
http://www.sevenforums.com/drivers/6086-brother-mfc-240c.html
Mar 28, 2011 | Office Equipment & Supplies
How can I set my MFC-240C printer to print from my computer
switch on the printer
1. install driver for mfc-240c
2. go to control panel in your computer
step to control panel
select START then control panel
3. select printer mfc-240c right click on it and then click on click on <Set as Default Printer>
4. right click again on it the select <properties> then select "print test page"
test page will printout on printer
5. now you can use mfc-240c as printer
Aug 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do i reset my brother printer to factory settings
To clear all memory on the MFC 240C, start by entering the Maintenance Mode:
  • Menu
  • Black Start
  • Up-arrow
  • up-arrow
  • up-arrow
  • up-arrow
Ignore all the beeping while you do the above. If you take too long, it probably won't work, and you'll be in a menu somewhere. It should come up with MAINTENANCE in the display. If not, press the Stop button and try again.
Once there, you have a choice:
  • 91 to reset everything except your phone numbers
or
  • 01 to clear EVERYTHING back to it's fresh-from-the-box condition.
Enter just the two-digit number, the machine will do the rest. After the display returns to MAINTENANCE, enter 99 to exit to normal mode.
Dec 23, 2009 | Brother Multi-Function Center MFC-240C...
I turned the printer off at the powersave button but now I can't turn back on..help?
Unplug the MFC 240c from power. Wait five minutes. Open the case, like you are going to change the ink cartridges. Close the case. Plug the MFC 240c back into power. Wait until it resets itself, then press the Power On button, and hold it in until the printer powers up.
May 07, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC Shows Offline
If you go to this page on the Brother site:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
you can view all of the available downloads for the MFC-240C. (Just select your operating system and language.)
Dec 09, 2008 | Brother Multi-Function Center MFC-240C...
Installation of MFC-240c
go here to get printer driver
www.brother.com
d/l by model and operating system
go for it then
Aug 14, 2008 | Brother Multi-Function Center MFC-240C...
Brother mfc 240c
you have to install the paperport software. This should be done when you have run the whole mfl-pro suite.
go to progr. /scansoft/paperport/ click scanner and simply scan into the paperport desktop.
Feb 28, 2008 | Brother MFC 240C All-In-One InkJet Printer
Error change unable 51
Unload the software. Restart the computer come off line. disable the anti virus Re install follow the prompts exactly. If still introuble take a look at www.fixyourownprinter.com
Aug 31, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
315 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
