Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp C6180 priner keep looping thru the power on startup
Need a hard button reset sequence.
MY BLU BOLD STUDIO 5.5 C D690U KEEPS LOOPING ON STARTUP SCREEN. I NEED HELP
not sure with that model, but you can usually do a reset by turning it off and holding volume button and power down to restart if its an android.
Jul 09, 2016 | Blu Cell Phones
How do i reboot my hp c6180 printer
This seems to works for me and doesn't appear on the HP support site nor in the manual...
1. Power down the printer (use on/off button) and remove power cable. Wait 2 minutes.
2. Hold down Help and OK buttons together while plugging in the power cable.
3. I held the buttons for around 5 seconds and when I released them, the printer seemed to go back to a hard reset - all sorted!
Hope this helps!
R
Jan 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer never completes the startup sequence, it
just reset the printer
unplug the power cable without turning off the printer
press and hold # & 9 Button
while holding down pluggin the Power cable and it will reset the printer (everything)
**** U will lose everything that has been saved in the printer settings
Oct 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 boot - init loop / power on-off loop
The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Impropershutdown
Press 6 and # while disconnecting the power cord (wait a little bit) and connecting it again. When the display is turned on again you can release the buttons.
After this reset you need to enter language, location and any wireless settings etc.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 All-in-one: On-off loop never stops
while the printer is on remove the power cable from the printer then press # and 3 on the printer together and then while pressing the buttons insert the power cord n then leave the buttons
if still problem persists then try the same thing by pressing # and 6
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180
unplug the printer and then plug it back in. turn it on and Hold the 6 and # button until the printer shuts off, this should do a hard reset
Apr 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
