Question about JVC AV-36230 36" TV
Tv screen keeps going black on my 36" tv but there is still sound
    Scholar:
  • 53 Answers
Hello Munroe the problem is coming from a fautly flyback transformer or a faulty horizontal output transistor, what i would suggest is tap your tv set on the side if the picture comes up than this is bad soldering on the one of this circuits above and this is an easy fix, if it turns out to be bad solder on the pc board take it to a near by tv repair shop this fix should not be more than 50 dollars or so depends on the repair shop,Thank You hope this helps have anymore questions feel free to ask me.
Posted on Sep 07, 2009
5 Suggested Answers
  • 135 Answers
SOURCE: 1999 36" Flat screen Sony Trinitron TV
Hi there!
There may be dry joints in the Line Stage where the Line Transformer is situated. The move may have loosened some components off the board. If not familiar with TV Electronics please refer to a repair technician. Regards and good luck, JUS004
Posted on Apr 02, 2008
Benimur
  • 6966 Answers
SOURCE: Toshiba 36 inch TV (8 Years Old)
If the shrinkage is just the top & bottom then it is relatively easy/low cost fix. Most probably, a capacitor in the vertical section is nearing end of its life. This would be the biggest of the bunch and would be something like 47uF/50V.
If however, the shrinkage is on all four sides, then it is the master power supply that is at fault. Chances are the main B+ is getting low which cold be caused by the big filter capacitor or an erratic regulator. This is not a simple fix and would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 10, 2008
bhatgiri73
  • 106 Answers
SOURCE: My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Posted on Apr 02, 2010
Testimonial: "Great response... I basically needed to know if it is worth fixing (if its the tube) I like this tv and don't want to ditch for a new flat screen. thx"
lovejoy91
  • 691 Answers
SOURCE: My 8yr old hitachi 36" tv keeps going in and out.
This is what is called the vertical IC, This is a flat ic on a heatsink and it could be label LA-______ something, I don't remember if it's 1601 location or what. also change out caps, like 100uf and 220uf, around this ic also loose connection are a problem with this too.
Posted on Mar 05, 2011
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
36 INCH 1997 - 1998 SONY TRINITON
Proceed with caution! High dangerous voltages exist within.
Check the current sense circuit from the aquadag coating.
Jul 15, 2017 | Televison & Video
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Black screen but have sound
If it is not a hardware problem, it is most likely the Closed Captioning system.
If you can still see the on-screen menu, go into your TV's menus and disable Closed Captioning.
May 14, 2008 | Toshiba 36AX60 36" TV
Cable tv issue
first ,replace the tv-dvd cable,then ask me again.
May 04, 2008 | Toshiba 36A40 36" TV
Hi there!
Mar 31, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Black screen
The blinking light is an error code. you need to count how many times it blinks, and check a service manual to see what the problem is, or ask a service person.
Feb 21, 2008 | Sony FD Trinitron KD-36XS955 36" TV
JVC AV-36230 36" TV Logo
443 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
