Question about Pioneer Elite PRO-1540HD 60 in. Plasma Television
Image size too big
The image size is too big and I'm loosing parts of the screen at the top, bottom and sides. Changing the screen display on the remote does work, but the image size is still too large.
  • pwesthorpe Sep 08, 2009
    It is not in zoom mode, it is in standard wide. I have also set it to automatic and have the same issue. I have seen other postings from others with the same issue. Is there no other resolution?
    Top Expert:
  • Pioneer Master
  • 75,822 Answers
Are you using the "zoom" button on the remote? also is the Aspect ratio set right, u will have wide screen settings and full screen settings, make sure these are set correctly, esp the zoom setting. u don't say when this problem happens, all the time on boradcast/cable TV, DVD player? DVD playere also has zoom control that will oversize the image..
Posted on Sep 08, 2009
  • 601 Answers
Is the TV HD ready or 16:9 compatible? If so, there are settings in the user's menu to adjust the aspect ratio of the set. Usually giving selections for auto format, 4:3, 16:9 cinema, or wide, stretch, and so on. If it offers automatic aspect, that's the way to go. Sounds like it's in the "zoom" mode (if it's a 16:9 capable set). If it's not, there is likely some adjustments needed by a technician. The service menu will need to be accessed. I do not suggest the customer try to use the service menu, since there are several alignment settings that can really screw things up if maladjusted.
Thanks
Smith.
Posted on Sep 07, 2009
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
My new lg 3d tv is closng on top bottom and sides is there anything i can do to cure the problem
Could you provide more information? What do you mean when you say, "closing?" Do you mean there is a black band around the picture? If so that means the original picture is recorded at a lower pixel density than your TV will display.
In the past most TV program signals provided a picture dimensions (in computer standards) very roughly 600 pixels wide by 400 pixels tall. What this means is that a picture of that pixel size will display as a small, squarish image slightly wider than it is tall on a (now) standard 1080p LCD television--which produces an image 1920 pixels wide by 1080 pixels high.
That would be nearly unwatchable (picture too small) except for the fact that most TVs compensate for the relatively small size of "standard definition TV (SD TV, as opposed to HDTV) by enlarging the image so that the top and bottom edges of the picture touch the top and bottom of the TV screen. This will leave black bands on either side of the picture. Some LCD TVs will automatically stretch BOTH dimensions of the image, which yields a distorted, "sqaushed" image.
All my comments above apply to both standard LCD and 3D-LCD TVs, by the way.
A more precise overview of the facts about TV picture size can be found here:
http://en.wikipedia.org/wiki/Display_resolution
Nov 23, 2013 | LG 42LW5300 42 Class 3D LED HDTV
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Ds lite case repair
Ok i can tell you how to do this.
First of all you need to make sure you have a new shell and the tools needed for the job, listed below.
  1. NDS screwdriver - $9.99
  2. #00 screwdriver - $9.99
  3. small pair of adjustable pliers (for replacing case).
  4. Soldering Iron (required to replace top display screen or case)
image 1.
OK. Look at image 1 above. Remove all the screws circled.
if you need to access the top of the DS Look at Image 2 below & remove those screws.
Image 2.
*Tech NOTE * Be careful not to lose ur shoulder button shaft and springs (Image 3 circled in RED) they will come out on you.
Also you will see a small cable circled below in Blue (image 3) Only remove this if you absolutely have to, this connects your display touchpad to your motherboard and can be very difficult to reinstall.
Image 3
Their will also be a white cable (not in pic) this can be unplugged by lifting the little round connector with your fingernail; allowing you to pull it through the hinge.
If you unplug the Black cable and pull it loose, you will definitely have a difficult time getting it back underneath its socket. It's easier to desolder it from the board in the top case ( Image 4 in green)
Image 4
I know this is a lot, just bear with me we're almost done.
This next part you have to use EXTREME CAUTION
To unplug your display cables (image 5) you will have to very carefully lift the little black latch on the connector. You will have to use 2 fingernails, one on each side, to lift these off. IF you only lift from one side you will break the Black latch on the connector making the entire board - garbage! Same for reassembly - be wary pushing the latch back down. The top cable circled in Red is for the bottom display. The bottom one is for the top display. There will be a single screw holding the MotherBoard in place. Remove it and lift the MB out carefully.
Image 5
IMAGE 6
Above (image 6) is the Bottom display assembly. The 3 pieces are held together with adhesive. The display is on teh bottom, the Touchpad in the center, and the top is the protective shielding. They can be pried apart carefully using fingernails or a plastic tool (be very careful not to crack anything)
IMAGE 7- TOP DISPAY
Image 7 is of the top display. Where you see the green circles is where the screw covers are located. use something very small to pry them out. Remove the 4 screws.
Hinge Removal - Image 8
Remove the two screws circled in Image 8 to get the hinge apart. If you are replacing your top display this will greatly help when you are trying to fit the cable back through the hinge hole. The Top can now be safely removed
**TECH NOTE**
Fitting your new cable through the hinge hole can be a bit frustrating. make sure you have separated the top & bottom cases to give yourself more working room. Remove the black and white wires, just out of the way. The cable will go into that thin slot a bit. When you reassemble it make sure to roll the end evenly from top to bottom first. This will help get it through the hole. Then put the round metal ring on afterwards, lastly put the wires through.
your speaker wires are soldered to your top display. To replace the case you will need to remove the wires to go through the hinge, and to replace the display you will have to remove them also (image 9)
Image 9
**Tech nOte**
when reassembling the top and bottom shell take note of the on / off button and the switch. Make sure you line the switch up with the button or you may break it***
Image 10
Image 10 - note the black wire that goes through the hinge. It is "jumped" (meaning it is connected to two places on the board, one next to the other)
Image 11
Image 11
The collar that fits inside the plastic case hole.
Image 12
Circled in green in image 12 is the angle adjuster. This is best installed with a small pair of adjustable pliers.
WOW... we're done!! As far as I can see this is a complete breakdown for anything you would need to fix. I hope this is a great help to you.
Please Rate highly if this helped you
^_^
Sep 17, 2009 | Nintendo DS Lite Console
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Pioneer Elite PRO-1540HD 60 in. Plasma Television Logo
264 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
