Question about Sony Playstation 3 (PS3) Console
Is there any other way to format an external hdd without the limitations of the fat32 file system?
  • 77 Answers
Fat32 is the only hdd format recognized by the ps3. if you have formatted the hdd to ntfs or other file system file convert it to fat32 for the hhd to be recognized by the ps3
Posted on Sep 07, 2009
Why can't my Toshiba ext hdd accept files more than 4GB? those files are .mkv formats. thanks!
The Toshiba is formatted with the 'FAT32' file-system, which is limited to 4GB per file.
Your 'C:' disk-drive is formatted with the 'NTFS' file-system, which has a much-larger limit.
So, use the 'DISKPART' command-line utility to "convert" the Toshiba from FAT32 to NTFS.
DISKPART is easy to use, but be careful to use it correctly.
Apr 23, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
How to connect storage media to ps3
If you mean a external HDD then you need to be able to format the External HDD so its a FAT32 and not NTFS file system. The PS3 wont recognize any other file system. You can do this with swissknife.
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
Recently i purchase a new 250gb external HDD it's coming into ntfs format by default... now i want to format into fat32, so that i can use both of my pc windows and mac.... (mac is not supportable ntfs...
DEAR A FAT32 SYSTEM SUPPORTS A MAX VOLUME SIZE OF 32 GB PER PARTITION SO MUST DIVIDE IT INTO THAT LIMIT I THINK YOU SHOULD HAVE UNDER STOOD. ANY VOLUME MORE THAN 32 GB (VOLUME = SPACE) IN NOT SUPPORTED UNDER THIS SYSTEM
Feb 04, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How do I format my WD MyBook Elite to FAT32
Using FAT32 these days on a current OS will half the
HDD storing capabilities especially if your unit uses'
a SATA HDD , FAT32 speed compared to NTFS is
less than half and the compression tool on NTFS
are more compact and compile better , also FAT32
is used to apply an operating system not for external
storage and if you are using your external storage HDD for holding an operating system to the HDD
will be suspectable to contracting viruses and
putting your data at risk , since the external HDD
is static and does not run through the OS registry
Jan 28, 2010 | Western Digital My Book Essential Edition...
So, my external hard drive was once used on a computer using Windows. Everything that has been installed onto this is locked. My computer is a Macintosh. I cannot add new files or delete the old ones from...
If your external HDD was used on a windows machine, it was probably formatted in the NTFS file format. Mac uses Fat32. The entire HDD has to be formatted to Fat32 for the Mac system to use.
Jan 28, 2010 | Maxtor OneTouch II Hard Drive
Format from NTFS to FAT 32
You'll want to leave this drive in NTFS format as FAT32 has lots of limitations in cluster size and total drive size.
The issue with your DVD- Media Player has nothing to do with how you formatted an external 1TB HDD.
It's possible that the two occured at the same time for different reasons.
Oct 15, 2009 | Western Digital My Book Essential 1TB...
Copying Files to PS3
Check what the "File System" type is by going to Start, Control Panel, Administrative Tools, Computer Management, Disk Manager. Select the external drive and read the "File System" type. The file system type must be "FAT32" in order for the Playstation to recognize it.
  • If the file system type is "NTFS", right click and select "Delete Partition" or "Delete Volume" for Vista.
  • then recreate the partition but do NOT format it. Make sure you assign a drive letter (for this Tutorial, we'll use h:)
  • If you are running Windows, format the drive by going to the command prompt (Vista, right click on command prompt in start menu and click "run as administrator")and type in "format h: /FS:FAT32" (without the quotes). You may need to substitute your drive letter. (note this will not work on XP for a large hard drive - you will have to use a third party formatting utility)
  • If you are using Mac OS X, open /Applications/Utilities/Disk Utility.app, pick the drive, and click on the 'Erase' tab. Pick 'MS-DOS (FAT)' for the file system type, and click on the 'Erase' button. This will reformat the drive in FAT-32.
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Can not convert it to fat or fat32 file system
Using disk manager, try to delete the partition. Then start over again.
Hope that helps...
Geno
Feb 27, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
Free space on my external hdd
Check the file system on your My Book. FAT32 has a file size limit of 4GB. I ran into the same problem when I tried to copy over a 4.5GB file from my laptop with NTFS on it. The file would not copy.
Nov 27, 2007 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
