Question about Cuisinart DCC-1200 Coffee Maker
The cuisinart repeated;y clogs and sprays water
The cuisinart repeatedly clogs and sprays water and grounds all over the counter top and floor
  • 8,596 Answers
The two most common reasons for overflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
My Cuisinart dcc-2600 does not distribute the water.
Over time, Calcium will deposit on the tubes and containers which get in touch with water. This can clog the Percolating tube, resulting in low or slow water circulation.
The calcium can also impact the function of the Heating elements in the percolator tube.
Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water. .
I would repeat this process every month or so if you use your machine daily.
If this does not solve, try contacting cuisinart customer service at 1-800-726-0190
Jun 08, 2012 | Cuisinart Dcc-2600 14-Cup Coffee Maker
Prepare the pot the night before and by morning all the water in the reservoir is on the floor or the counter!
I have had our Bur Grinder Cuisinart for a little under a yr. with no issues until recently when it started flooding my counter top. I could tell it had something to do with the lid or filter button that touched the lid b/c coffee would begin to "pool" and then flood over the sides onto my counter. I contacted the number listed below on 10.25.12 and was told our model's lid had a defect and they would send me a new one to resolve the issue.
Cuisinart Warranty 1-800-726-0190
Sep 04, 2011 | Cuisinart DGB900BCU Grind and Brew 12Cup...
Cuisinart DCC-2000 coffee maker LEAKS all over my counter . How can I make it stop?
There are a few issues that could be causing this depending where it is leaking from.
The most common leak occurs from coffee grounds. If you over fill the basket or if you are using too fine of a grind (especially if you grind your own coffee) it can clog the filter.
Try using less coffee grounds. The MAX recommended capacity is 15 tablespoons. If you are grinding your own coffee, try a less fine grind. If using already ground coffee, try switching to a different brand.
If this does not work or you are leaking from another spot, clarify and we can try to nail down what the issue may be.
Feb 28, 2011 | Cuisinart DCC-2000
How to make a d-link 264 ob into a repeater I have a three story house with wireless on the ground floor and the signal is very poor at the top. I want to repeat the signal on the second floor.
Move your wireless to the second floor or add a second wireless router to your second floor. Use CAT 5 or 6 cable. Run it in a closet or cold air return. Use the special cat 5 or 6 for cold aire return use. Do not put it in a heated duct.
Dec 09, 2009 | Computers & Internet
Coffee leaks all over the counter every time coffee is made. coffee appears to be coming out of bottom of machine Coffee pot lid is on correctly.
I had this problem after about a year of use. The thermal carafe lid had become clogged enough with coffee sludge (fine grounds/oil) and hard water deposits to slow the flow through the lid. I soaked the lid in a bowl of 2 cups hot soapy water + 2/3 cup white vinegar for a few hours, agitating the lid in the mixture every 1/2 hour or so.
Then, I rinsed the lid and packed baking soda in every opening and dropped it back into the mixture - hoping the fizzing action of the baking soda+vinegar would help loosen any remaining sludge.
I rinsed it again, and whacked it against the side of the sink for a final effort to loosen sludge. Repeated the baking soda + rinse + whacking a couple of times. No more problems.
In the future, I plan to do the soak at every Cleaning cycle/every couple of months.
Or, if you don't want to deal with it, replacement thermal carafe lids are available from Cuisinart for $6 + shipping.
Jul 29, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
1,024 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
