Question about Refrigerators
Why is it that the thermostat setting is in 0 and yet the ice is so thick
2 Suggested Answers
SOURCE:
etudelashes
  • 246 Answers
SOURCE: Line clr60b wont stop making ice
http://www.aramislashes.com/wholesale-mink-eyelashes/wholesale mink eyelashes WHOLESALE MINK EYELASHES MANUFACTURER-ARAMIS LASHES Our wholesale mink eyelashes is more lighter,softer and more Flexible, our 10 year's experience in wholesale mink eyelashes can bring you more hot fashionable mink lashes, you can get top quality from our lashes factory with fast delivery. Most luxury package wholesale mink eyelashes box is available.
Posted on May 08, 2018
May 08, 2018 | Ice Kitchen Appliances - Others
My ice maker keeps on getting clogged up and won't dump ice!!! Is there something I can do to correct this?
The most common cause for this problem is setting the freezer temperature to low. If digital, set to5 degrees, if rotating thermostat, set mid scale (example 0 to 7, set to 5)
Setting temperature to low causes the dispensing flap to frost up to not close properly after dispensing. If it does not close even more frost forms and ice starts slumping together causing ice to jam.
Hope this helps!
Apr 18, 2016 | Refrigerators
I have a ice-o-matic 400ha2 ice machine that is not making much ice and is to thick. the timer has been replaced,but no change
reduce the thickness thermostat that initiates the timer to minimum, then increase until good ice made.
Aug 29, 2014 | Kitchen Appliances - Others
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Hoshizaki M# DCM-270BAH-OS runs for days then freezes up evap coil and stops water inlet to evap.
There is a thermostat probe sat on the front of the evaporator to tell the control board when to harvest. Check it is tight in it's holder. Check the condenser is absolutely clean and filters clear. You can adjust the thickness of the cube. set it on the thinnest setting and see if it harvests before freezing solid.
Jun 15, 2012 | Hoshizaki Freezer Commercial Ice Machines...
What is the ideal temp setting in GE side by side refrigirator. I have Freezer (0-9) Refrigirator (0-9) There was ice on the Freezer wall and the service guy replaced the defrost thermostat recently
If replacing the defrost thermostat fixed the icing problem that doesn't indicate your settings are wrong. But the desired temp in the freezer is from 0 to 10 degrees and in the fridge around 35 degrees.The actual number on your dial depends on the personal use. Use a thermometer to check it and allow 24 hours after changing it to check it.
May 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
If my ice cubes are incomplete from my manitowoc ice machine and I sometimes here them falling early and hitting the bin before it dumps. Is the ice thickness set too thin or too thick? Thanks for your...
The ice thickness is too thin...
turn the screw on the ice sensor IN or clockwise about 1/8 turn at a time till you get the right thickness...give it a couple of dumps before making another adjustment after doing the first one...be careful as the sensor is very sensitive and can be knocked out of wack very easily...
heatman101
Sep 28, 2010 | Refrigerators
Freezer had been working well for a month or more, then following it being moved possibly as a workman was checking my appliances for leaks, the top of the inside grew thick ice. I defrosted it but within...
Normally that amount of ice denotes a leak in the system, or possibly the thermostat not switching off. If the door does not seal correctly, you will also generate a lot of ice. Something tells me we are looking at a leak.
Oct 23, 2009 | Candy Freezers
Build up of ice
YES
The thermostat is not cutting out.. It needs to be replaced.. Your compressor risks burning out if its is continoulsy running ...
Nov 14, 2007 | Hotpoint RLA30 Compact Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
