Question about Kenmore Oasis HE 27082 Top Load Washer
Went on by itself and started filling/draining water
Kenmore Elite Oasis Model 11027062603. Went on by itself in the middle of the night--water was going in the tub. No lights on control panel. Had to turn off water supply (used all the hot water) and unplug machine to get it to stop.
  • 1 more comment
  • msilvic Sep 07, 2009
    Is it the control unit assembly or the user interface? -- When I plug it back in water still goes in the tub (even though the water supply is shut off) and if I hit the power button the panel does light up.
    No. The machine was turned off. Just plugged it back in, and it died--I think the control unit is definitely shorted out.
    Thanks anyway.
    Guru:
  • 1,326 Answers
Was the timer set for delayed wash cycle? The new digital machines can be pre set for washing at a specific timeframe. If no time set then you can try unplugging it for 5-10min. THis usuallly resets the computer. If it does't resolve your issue you probably have a bad control board..
Posted on Sep 07, 2009
  • James Brooks
    James Brooks Sep 07, 2009
    It would still pump out water if the unit has filled from it running. Let is pump out all the water in the unit. More then likely its the probably not the inteface board ad that's just the input (like a keyboard and mouse on a PC) they tell the control board what to do. It may be a short or just faulty component on the board. Unfortunately electronics tend to do this thing. My Bosch washer errors out every now and again and I jsut unplug it. At some point it will not solve the issue and I will have to repair/replace that same board.
  • 430 Answers
This is a matter of faulty Control Board. You can order the parts which needs replacement at 1-800-507-4040.
Has my Kenmore Elite Model 110.27082603 been recalled?
I am trying to find out if my Kenmore Elite Oasis HE model # 11027062603 has been recalled. Thanks
Mar 28, 2013 | Kenmore Oasis HE 27082 Top Load Washer
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Noise sounds like loose change or screws.
You probably have something in your pump. Remove the lower front panel (3 #20 torx bit screws) In the bottom, middle there will be a large white pump. I usually remove the screw holding it in so I can get the edge of a bucket underneath it. Once you rotate the knob in the centercounter-clockwise and the water drains out, remove any forign objects.
Jun 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
