Question about Dell 922 All-In-One InkJet Printer
Printer shows green light 'on' when plugged in but wont do anything, scan, print or copy and wont switch off unless I unplug it.
    Master:
    Sergeant:
  • 460 Answers
First you can refix the printer catridge. if problem is not solved then it is logic card problem, so you can checked it from printer vendor.
Posted on Sep 07, 2009
How do I reset wf 3540 printer to factory default to eliminate the driver updates software problems
Turn it off, if you can. Then unplug it from the wall and wait for it to shut itself down. Then plug it back in, wait, then push the start button.
It should have recycled itself.
Aug 15, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
The power light and the copy, scan and fax lights all come on and stay on and I cannot use the printer. I have to unplug it printer and plug it in again in order to print. Now the lights stay on all of...
Remove the cartridges from the printer then close the cover. Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord plugged in to the power source. Bypass any surge device or power strip, plug the power cord straight to the power outlet in the wall. Wait at least 30 seconds before plugging the power adapter back in the printer. If all the lights still come steadily on, it's a hardware problem. If not, when it's ready, reload the cartridges. Let it print the alignment page. Then check if problem persists. If it does, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
My printer has an exclamation point light flashing a< it will not print or copy, fax, scan or anything. I unplugged it for 30seconds and still doesnt work < what do i do?
Try going to the control panel in windows and selecting "Add New Hardware". then plug in the printer.
The other method may require checking with the manual. you might need to install software before plugging connecting it to the computer.
May 18, 2010 | HP Laserjet CM 1312NFI Color Printer
My HP C6180 has suddenly stopped copying. All other services work fine (fax, scan, print etc). It selects the paper, the dispay shows it copying...but it doesnt do anything else. I have to power it down...
What you can do is reset the Printer
Unplug the power cable...........
Press and hold # & 9 Button
while holding down plug in the power cable
This is the Printer Reset
But this will erase all the setting in your printer
Oct 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
HP psc 750 printer
my computer said that it did not have it on the computer I've used the CD .
May 21, 2008 | HP PSC 750 All-In-One InkJet Printer
Printer
unplug the cable from the computer to the printer, make sure you got all of the jam out. Unplug the power from the wall wait a few seconds and plug back in. (with usb cable still unplugged)Then try deleting all documents from the que. If the machine is in the ready mode, (green light on) plug usb cable in and try again. Let me know if this solves you problem. If not we can try a few other things.
Jun 29, 2007 | HP DeskJet 3740 C9026A Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
