Verbatim VER95327 USB Hard Drive
Problem for Verbatim VER95327 USB Hard Drive
External hard drive model #47560 wont display on
By dave_hamlin on Sep 07, 2009
external hard drive model #47560 wont display on "My Computer" im runing vista ??
Best Solution
posted on Sep 07, 2009
Very Helpful)
bob_computer
Rank: Guru  Computer Accessories  Expert
Rating: 87%, 1196 votes
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Verbatim VER95327 USB Hard
Questions and Unsolved Problems for Verbatim VER95327 USB Hard
Do you recommend Verbatim VER95327 USB Hard Drive?
Answer
Answer
How to gain access to my desktop hard drive user manual
Answer
i have a verbatim 1tb external hard drive. i usually have my hard drive left on everyday. i turned... (More)
Answer
cannot remember password for verbatim 1gb drive
Answer
I sent mine back three times. Same problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Verbatim VER95327 USB Hard...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14808
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
