Question about HP ScanJet 3200C Flatbed Scanner
Switching adapter that i will use on 12V 1A flatbed scanner
  • 6 Answers
This would not be a very smart move!
I made a mistake and plugged the wrong power adapter into the scanner and the second it made contact, heard a pop like a diode discharging and scanner became a large paper weight or memory on a mantle piece.
I would not recommend using anything other than the required voltage and amps.
Posted on Mar 09, 2008
Linksys wrt54g manual
Power specification depends on the Hardware version
WRT54G 5V 2A
WRT54G V1.1 12V 1A
WRT54G V2 12V 1A
WRT54G V2.2 12V 1A
WRT54G V3 12V 1A
WRT54G V3.1 12V 1A
WRT54G V4 12V 1A
WRT54G V5 12V 0.5A
WRT54G V6 12V 0.5A
Nov 28, 2013 | Computers & Internet
I have a blackberry 8520 and i want to reset my blackberry username
Power specification depends on the Hardware version of router
WRT54G 5V 2A
WRT54G V1.1 12V 1A
WRT54G V2 12V 1A
WRT54G V2.2 12V 1A
WRT54G V3 12V 1A
WRT54G V3.1 12V 1A
WRT54G V4 12V 1A
WRT54G V5 12V 0.5A
WRT54G V6 12V 0.5A
I HAVE LOST THE POWER ADAPTER, CAN YOU SUPPLY A NEW ONE?
this one will work. http://www.buy.com/prod/belkin-12v-dc-power-adapter-20w-belkin-12v-dc-power-adapter-20w/q/loc/101/10296195.html
Mar 30, 2011 | Umax Astra 1220U Flatbed Scanner
Will a different power source work?
You can go to walmart or electronics store and purchase a universal power adapter. It has switches on it that you can set the voltage and amps, and different inter-changable tips that fit your scanners socket. ...about 10 bucks
Apr 22, 2010 | Visioneer OneTouch 7600 Flatbed Scanner
I lost my power supply. what is the polarity and voltage of the power input?
HiTron
Model: HER-48-12010
Input 120V~60Hz, 0.25A
Output: 12V 1A
Apr 05, 2010 | Umax Astra 1220S Flatbed Scanner
Can a 12V 6A power adapter replace a 12V 1.5A power adapter?
I'm not an electrician, but I do know that as long as the voltage matches EXACTLY (don't take the chance, most devices don't have a good resistor, or don't have one at all!), the current doesn't matter. I'll explain myself:
A consumer device (your scanner in this case) uses all the current it needed, and it practically doesn't need more! It take just what's necessary!
Connecting adapter which provide LESS is not enough, but more - isn't harmful!
Hope I helped,
Pelu.
Mar 14, 2010 | Canon CanoScan 4400F Flatbed Scanner
My daughter has acquired a Mustek 600 III EP Plus scanner, unfortunately without a power supply. I know it is 15 volts 1 amp dc, but is it +ve or -ve tip?
Mustek 600 III EP Plus scanner, Power adapter type output +15VDC/1A Positive Polarity (positive inside and negative outside).
Sep 25, 2009 | Mustek TwainScan 600 III EP Plus Flatbed...
Need power supply for UMAX Astra e5420 acanner
From a quick search I found this power supply, from Umax.com,
http://umax.com/scanners/index.jsp?cate=Scanners%3A+Accessories&skunum=68300055-0000
Jun 03, 2009 | Umax Astra 3450 Flatbed Scanner
Unsure about power supply
Don't know if you've got round this by now but the supply needs to be 12v 1A with the inner positive
Dec 21, 2008 | HP Scanjet 4400c Flatbed Scanner
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
HP ScanJet 3200C Flatbed Scanner Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
