Question about Amana Freezers
EL CONGELADOR NO BAJA DE LOS -10º C. Y LA CUBITERA GOTEA POR DOS SITIOS MOJANDO EL HIELO DE LA CUBETA HACIENDO BLOQUES DE HIELO ENORMES.
PARECE SER QUE LA FALTA DE FRIO EN EL CONGELADFOR SE DEBE A UNA FUGA DEL GAS. EN CUANTO AL GOTEO DE LA CUBITERA, ES LA JUNTA DE ESTANQUEIDAD, QUE SE HA PASADO.
Posted on Sep 08, 2009
Necesito reparar el mecanismo rotativo de los shelves o compartimentos. Que numero de la parte o motor debo instalar?
Antes de gastar en partes nuevas, debes desarmar el aparato y inspeccionar. Le llega la corriente al motor? Funcionan los switches de limite (que detienen al motor en su punto), algun engrane, o fusible quemado?
Dec 31, 2014 | True G4SM-23-RGS Reach In Specialty...
Lo conecte un instante a la 220 volt por error y ahora no funsiona ?que le pasa?
if you connected a 110 v unit to 220v out more than likely you would have damaged the control circut. but if didnt hear anything pop or burn try it in the correct outlet. If its responding then you need a service person to test the components.
Mar 06, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FRIGIDAIRE FVE1415 UPRIGHT FREEZER START RELAY BURNT OUT ON RESTART AFTER DEFROST
Contact hot point or kenmore. Often times there are cross reference parts that will work. This freezer is not much more than 7-8 years Los.
Jan 25, 2013 | Freezers
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
Je veux enregistré mon produit
Please clean your freezer, check compressor and set your thermostat to middle and observe your freezer.
Nov 07, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Frezeer fz90 thye hight temp light is on and the food is de freezing and we would like to know what the dial be on
the food in the freezer is getting warm (de freezing?) because you have a faulty part. changing the dial now wont do any good, but it should be in the middle setting. I cant tell what part is bad with your lack of description.
Mar 20, 2010 | Freezers
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 | Freezers
Funde los fusibles del portafusibles del carro
tienes un corto en alguna parte identifica cuanles son los fusibles y revisa los circuitos no antes de ver si los fusibles son de la capacidad necesaria
May 25, 2009 | Coleman Freezers
Freezers Logo
88 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Gil Shultz
Charles T Nevin
Charles T Nevin
Are you an Amana Freezer Expert? Answer questions, earn points and help others
