Question about Samsung SyncMaster 710N 17" LCD Monitor
Is my monitor dead?
I have a screen that has blacked out, with a floating box that says maximum resolution 1280 x 1024 60hz, the screen was working for awhile then the floater shows up. Is there a reset button or anything I can do?
  • 3 more comments
  • Anonymous Dec 11, 2007
    same problem but since the begining... Since out of the box, the screen never showed something except that message... windows boots in 800x600 60hz normally but no changes...
  • chjung Dec 25, 2007
    Similar thing here:
    I purchased a SyncMaster 710N second-hand. Whatever setting I choose in WinXP, the monitor does not display anything except
    "not optimum mode
    recommended mode: 1280x1024 60 Hz
    When I actually set the graphics adapter to those settings, I get the message
    "not optimum mode
    recommended mode: 1024x768 60 Hz
    ... but this does not work either.
    I installed the appropriate driver from the Samsung homepage.
    I tried to connect to 3 different PCs, always the same result.
    Any good ideas?
  • kensitt Jan 01, 2008
    I have the same but cannot get on to desktop to change resolution, I cannot get past the floating box screen.
  • Anonymous Jan 17, 2008
    I have had 6 Samsung monitors on my pc (multi-screen arrangement). Two of them show the same problem ater several years of use.
  • frusta6 Jun 12, 2008
    My 710N
    Problem Solver:
  • 3 Answers
Solder a 50 ohm precision resistor between pins 5 and 6 of the Novatek NT68F63LG
I had this same problem on 3 Samsung 710N displays and this fixed the problem.
I have read others have also been successful but the value of the resistor was slightly different in some cases. I would start with 50 ohms as that seems to be a common value fixing most displays.
Here is the reference URL to the ORIGINAL person that solved the problem.
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
Posted on Dec 12, 2008
We bought about 20 of these for a computer lab at a university in summer 2005...after a little over 2 years this problem started coming up. In the last 6 months we have had to send in 8 of them for replacement.
If you are sure you have the computer set to the right resolution and the machine will display to other monitors - send it in for an RMA.
Posted on Feb 27, 2008
    Problem Solver:
  • 19 Answers
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
Posted on Jan 16, 2008
Problem with firmware of Novatek (NT68Fxx), it can be fix in samsung SC.
Posted on Oct 31, 2008
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Displays 'Input Not Supported' at start up om black screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Sep 20, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
Black screen with box of 'Suggested resolution 1280 x 1040 60Hz'
The Samtron 73V has a maximum resolution of 1280*1024, are you running at that resolution ?
Mar 15, 2009 | Computers & Internet
Samsung SyncMaster 931BF 19" Monitor. Screen was working fine. But now after raising the resolution past 1280X1024, the screen wouldn't display anything. I tried it on my older monitor, a CRT. It...
This is because your screen is not compatible with any resoultion past 1280 x 1024. Look at your screen's specifications here: http://downloadcenter.samsung.com/content/UM/200602/20060210090838125_BN59-00521A-01Eng.pdf (Page 76 listed as Maximum resolution)
If you want to go past that, you must purchase and/or use a different monitor. Just be sure to look at the Maximum Resolutions BEFORE you purchase a new monitor!
Nov 25, 2008 | Computers & Internet
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hi receiving input not supported
This message shows that you are not setting the resolution correctly.
When you are in Windows, click on - Control panel - Display - Setting - Screen Resolution (set yo 1280 x 1024). then click ok.
Your floating box will gone.
I got the same problem and got the solution from rma@rosewill.com.
Hope this will help you.
Ringo
Dec 13, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Benq monitor fp51g
What's the owner's manual say that means?
Jan 13, 2007 | BenQ FP51G 15" LCD Monitor
Samsung SyncMaster 710N 17" LCD Monitor Logo
3,848 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
