Question about GE Profile JGS968 Gas Kitchen Range
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
  • 8 more comments
  • Anonymous Dec 16, 2007
    MY FAN TURNED ON AND STAYD ON EVEN WHEN EVERITHING IS OFF I TRIED RESETTING EVERITHING, CLEANING THE RANGE BUT NOTHING, I UNPLUGED IT NOTHING?
  • jessie2796 Mar 17, 2008
    I'm having the same issue.... I have search for a week now for what I think is the part I need.... any luck with yours?
  • lhauer Oct 05, 2008
    I have the same problem, fan turns on, but it does not heat up. The broiler and the stove top burners work properly... I have had this gas stove for 4 years.
  • tmanus Oct 10, 2008
    I have the exact same problem, everything works but the oven on bake mode, broiler works and temp reads 100 degrees. I have not been able to find a solution on the internet, I guess I will soon call the repair guy.
  • Anonymous Oct 16, 2008
    Its the oven ignitor
  • MASON679 Oct 30, 2008
    SAME THING BROILER WORKS - CONVECTION AND REGULAR OVEN DOESNT-- STARTED ALL AT ONCE. STOVE IS ABOUT 2 YEARS OLD OVEN HASNT BEEN USED MUCH. THE TEMP READS 100 DEGREES AND THAT IS AS FAR AS IT GOES--- PLEASE HELP
  • Anonymous Nov 02, 2008
    Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress problem, and notify you when a new solution is offered.
  • KC1963 Feb 15, 2009
    Anyone had any luck with this issue? Ignitor?
  • jbindc Feb 24, 2009
    Same problem here. Fan goes on, but oven doesn't heat up and temp stays at 100 degress. Broiler still works. Just bought the house 6 months ago, so not sure how old the stove is. Did anyone ever find a solution?
  • Anonymous Mar 14, 2014
    THE BROILER ON MY FRIGIDAIRE GAS RANGE MODEL NUMBER PLGF389CCB DOES NOT IGNITE. OVEN (BAKE AND ROAST), WORKS OTHERWISE.
    Sergeant:
    Champion:
  • 310 Answers
Natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
My broiler works but not the baking (Lower) burner?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 11, 2011 | GE Profile JGS968 Gas Kitchen Range
My jgs968 oven won't light. It stays at 100. The burners and broiler work
heatman101
m,b,m
Jun 24, 2010 | GE Profile JGS968 Gas Kitchen Range
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Aug 01, 2009 | GE Profile JGS968 Gas Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Jan 28, 2009 | GE Profile JGS968 Gas Kitchen Range
Oven and broiler won't ignite, burners are working
My gass range top works but the oven doesn't light and it stays on 100%
Oct 10, 2008 | GE Profile JGS968 Gas Kitchen Range
GE Profile JGS968 Gas Kitchen Range Logo
699 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
