Question about Baumatic B180 Electric Single Oven
Oven is not heating, grill is working, everything else is working
  • 1 more comment
  • asnebj Sep 07, 2009
    This is not a micro wave!!!!!!!!
  • asnebj Sep 08, 2009
    this is an electric oven
    thanks, but havent got a meter and dont feel very confident
  • 1,029 Answers
Check The fan at the the oven if it comes on and circular fan element dosent heat check and see if the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. hope this help
Posted on Sep 08, 2009
    President:
  • 1,865 Answers
Most likely the element needs to be replaced, but the only way to know for certain is to troubleshoot the problem with a multimeter
    President:
  • 1,714 Answers
Turn oven on. Look for glowing ignitor in lower oven. If there is no 'glow' coming from ignitor, ignitor is bad and needs changing. If there is glowing from ignitor, then the problem is the 'coil' on the gas valve. It's a solenoid electrical coil that activates the valve to open for gas.
  • Craig Butler
    Craig Butler Sep 08, 2009
    so sorry, I though it said gas oven. Now then, an electric is going to be even easier. CAn you check the element itself? Do you have knowledge about looking at the element to see if it 'looks' normal?
  • Craig Butler
    How far do you feel comfortable with troubleshooting the power in the oven? Do you have a meter?
    President:
  • 632 Answers
  1. Check the heating elements using an analog ohmmeter. Turn the knob to x1k or x10k marker. If the ohmmeter pointer does not deflect, the element is busted. You have to replace it completely since it's not repairable. The switch that controls it also fails and you have to replace it too.
  2. Check the receptacles where the heating elements are plug into for any sign of wear or bad contacts. Remove the elements by lifting it up and firmly pulling it away from the receptacle.
  3. Replace the element if its ends are corroded or burned and replace the receptacle too.
Posted on Sep 07, 2009
  • 3,230 Answers
You will need to look at and/ or test these three areas, if your microwave won't heat -
*Power diode
*High voltage capacitor
*or the Magnetron
for more information check the below link -
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
If the microwave sounds fine and there is no heat, one of the internal door micro switches, the high voltage circuitry, or the circuit board may be the problem and they should be tested and replaced as necessary.
Note. You need to be familiar with working on microwaves or at least learn how to discharge your microwave's capacitor; it is absolutely essential in preventing injury to your microwave, your tools, and yourself. A capacitor stores large amounts of electricity even when your microwave is unplugged, and it must be discharged before beginning any repair. I highly recommend having a qualified appliance repair technician work on the microwave.
Post further comments for more information....
Good Luck!!
Thanks
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
Using grill and everything tripped now grill or oven wont work
Electric grill most often uses heater element to heat up.Maybe your heater elemen is shorted to oven body thus tripping the safety device.
Check your grill system using insulation tester.If the insulation is low check the heater elemen insulation and if defective replace them.
Jun 17, 2012 | Zanussi ZBF360 Electric Single Oven
The grill on my oven will not heat up but everything else is working !
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 19, 2011 | Zanussi ZBF360X Electric Single Oven
My smeg willl only work on the grill setting,. when I use the oven switch everything comes on but it does not heat up
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 13, 2011 | Smeg SE280X Stainless Steel Electric...
Oven was on, heard a loud bang and everything went off, changed fuse, oven clock etc came on, grill works but oven does not work?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 19, 2011 | Ovens
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Wont get hot grill works think the element has
If it is a fan assisted oven, then it is probably the oven element that has failed.
This is usually located at the rear of the inner oven compartment behind a removeable panel
May 04, 2010 | Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Baumatic B180 Electric Single Oven Logo
140 people viewed this question
Top Baumatic Ovens Experts
ashburton
Dennis Boxerman
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
