Question about Panasonic PT-AE3000U LCD Projector
1. short lamp live 2. overheating - Panasonic PT-AE3000U LCD Projector
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
First, make sure you've cleaned any dust filters on the unit!! That in itself will usually stop overheating (think of someone closing off your nose and mouth) that's what happens when the dust filter gets clogged--the unit strangles for cool air and rapidly overheats--this not only shortens lamp life dramatically, but also shortens the life of ALL components in the unit, especially delicate LCD panels or the display chip in a DLP projector!
Posted on Sep 08, 2009
Mitsubishi WD-62526,no picture,no sound,status LED blinking yellow.I checked and cleaned filter also pulled,checked connections and reinstalled lamp.
According to the manual this means the Lamp cover door is open or lamp cartridge is not secure.
See Appendix F for lamp replacement information.
Apr 04, 2008 | Televison & Video
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
I TURN ON THE TV & TURNS OFF AFTER A FEW SECOUNDS
Check Lamp Fan and If Lamp has never been replaced ,then you could have Bad Lamp Mats has them for $89.00 1-800-629-1118. If they do not have Lamp then Look on EBay.
Jun 19, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Lights come on for about 2 min.and shut off. I turn off transformer for about 15 mins and turn on lights work for about 2 mins.
Unless you have the optional photo cell, I'd imagine you are overloading the transformer. Total up your lamp wattage and be sure it is less than the 300W rating of the transformer. The lights usually range from 10 to 50 watts, so you could have 30-10watt lamps or 6-50 watt lamps. The other possibility is that you have a short in your wiring or fixture. In either case if you overload the transformer it should cycle off to protect from overheating, and when it cools, it will restart. Try connecting just one luminaire to the transformer and see if it works. See link:http://www.malibulights.com
Jul 03, 2010 | Intermatic Malibu 300W Power Pack...
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Sanyo pro x projector turns off after a random number of minutes
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Apr 06, 2009 | Sanyo (6102932751) Projector Lamp for...
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Radiator fan does not come on, overheating lamp blinks
Disconnect the two fan plugs leads from the fan sensor switch in the thermostat housing bridge the two plugs with a wire if the fan starts then you will need to replace the fan sensor switch if not the fan will need replacing ,as for the temp light flashing with the indicator light maybe because they share the same fuse and they could share a common earth as well?
Cheers Michael
Nov 18, 2008 | 2001 Triumph Triumph Thunderbird
Panasonic PT-AE3000U LCD Projector Logo
175 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
