Question about Bosch Benvenuto B30 Espresso/Coffee Maker
Bosch Benvenuto TKN68E75 Coffee Maker. I have a blockage at coffee output point, I cant get into clear it
  • 7 Answers
On the bottom of the sliding spout assembly is a little tab (remove tray and look w/mirror). Once you depress that with a knife/fingernail/screwdriver, you can pry the cover of that assembly toward you on the bottom. Insert a screwdriver in the resulting slot on the side and carefully slide it up; the curved plastic cover with "BOSCH" on it will pop off. Don't worry, it's pretty flexible PVC.
Now pull on another (newly visible) tab on the bottom of the assembly (use mirror again) to disengage the entire spout mechanism (two black cylinders) which will then hang toward you by the coffee tube only. Carefully disconnect the coffee tube. Now you can wash them out (I do that every 6 months or so).
Best results: Hold one tube and the middle drainhole shut with your fingers and blow water hard into the outflow side of the other one (over the sink, of course). Repeat on other side. Soak unit in hot water w/soap, clean w/high flow, dry. Your view into the unit from the bottom (where the coffee normally comes out) should be unobstructed except for the PVC cross inside the tube.
Everything snaps back together very easily. The hardest part is connecting the coffee tube again, especially if you have big hands...
While you're at it, open the side panel below the bypass doser. On the brew group you can see three little plastic covers that, once pried off with a knife, reveal three 1/4 turn screws marked with an open and closed key symbol. Opening them will enable you to slide the brew group out and give it a good cleaning.
Take a vacuum cleaner with the narrowest attachment and vacuum all the loose coffee grounds out of the machine. Clean the inside as much as you can. Do not reassemble until the brew group is dry, otherwise the wet spots become caked with coffee.
Unscrew the steaming wand by loosening with a coin or knife on the bottom. It disassembles into a rubber holder, the metal wand, and the plastic frothing piece. Soak all three in a glass of hot water with soap. On the frothing piece there are two notches as well as a tiny hole that I usually have to clear with a knife tip. Insert a soapy Q-tip up into the pipe on the machine and "roto-root" it. Repeat with clean/wet Q-tip. If the outside of that pipe is dirty, tie a hot wet paper tower to it for 1/2 hr to soak it off. A Scotchbrite pad or steel wool will do the rest. If you maintain it this way every two weeks or so, it will never get caked up and you'll always have great foam.
Bosch factory support and local support is questionable, so I clean mine every 6 months or so, now that I know how to do it...
Posted on Sep 11, 2009
Testimonial: "Thanks a million for sparing your time and knowledge, your very detailed help has been invaluable"
  • Christine Braunstein
    Christine Braunstein Feb 05, 2017
    This solved my issue, thank you! The black cylinders were completely clogged with finely packed coffee. Once I thoroughly cleaned it out (very hot soapy water and a toothpick to get out the gunk) and snapped it all back together, my machine worked perfectly.
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ... > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ... > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Bosch buenvenito tkn68e coffee weak
The coffee machine started with a water leak. It comes from the inside of the machine and leaks in the inferior part of it. Any clue of what may be causing it?
Dec 02, 2013 | Bosch Benvenuto (TKN68E75) Coffee Maker
I have a B30 Coffee machine. The machine was struggling to make coffee and making a sound as if the machine was straining. I assumed the there was ground coffee clogging the machine so I opened the side...
As you need a technical manual for Bosch Benvenuto B30Espresso & Coffee Maker, but it is not freely available. If you agree to pay, you can get all kind of Bosch BenvenutoB30 Espresso & Coffee Maker manuals here: Afterclicking this link you will be forwarded to a page contains a form. You need tofill up that form. Most of them are pre-filled. You need to write "Bosch"in Brand box and model number in "model number" box. Please don'tforget to mention "Espresso & Coffee Maker "in the "description box".Finally accept their "terms and condition" and click on "search"tab. Downloaddocuments as per your requirement. Hope this will help you. Good Luck.
Sep 11, 2011 | Bosch Benvenuto B30 Espresso/Coffee Maker
Trying to locate a store where to find cleaning tablets for Bosch Benvenuto B30
You did not state geographic area. The part number is 310575
You can order them on line here: (10 pack $12.95)
also here: ($12.90)
There is a Descaling Maintence Pack 311196 That I would recommend everyone with a good coffee maker should use:
This is only on line sources.
Thanks for choosing FixYa,
Dec 10, 2010 | Bosch Benvenuto B30 Espresso/Coffee Maker
Can't make coffee
Thank you very mach, for support but I was had solution yesterday by user documentation. The mashine was blocked by electronic because was not clean very long time.
B.R. Petko
Jan 21, 2009 | Bosch Benvenuto B20 Espresso & Coffee...
Bosch Benvenuto B30
The cleaning program is different from the descaling program.
The machine is now wanting you to descale the machine. Get some descaling powder or tablets, desolve in water and let the machine run through the descale program.
May 31, 2008 | Bosch Benvenuto B30 Espresso/Coffee Maker
Cleaning products
I just ordered everything I needed for my Bosch Benvenuto B20 from  It was easier than my previous purchase from Bosch to find knowledgeable people.  I purchased Super Auto Cleaning Tabs, Cleancaf by Urnex, and Claris water filters online.  Just call them if you're not sure what to buy.
Mar 03, 2008 | Bosch Benvenuto B20 Espresso & Coffee...
Bosch Benvenuto B30 Espresso/Coffee Maker Logo
2,986 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
