Question about Enlight Computers & Internet
My BIOS Get Flash n Maybe I can Change my Bios But I Dont Know About Compatible Bios For ENPC E73. Do You Have Solutions ??? I Need ROM for ENPC E73
  • Alun Cox May 11, 2010
    What exactly is your problem and why do you think flashing your BIOS will solve it? A little more detail would help.
  • 77 Answers
Download bios firmware at your mobo's manufacturer website
Posted on Sep 07, 2009
Bios update failed.. Now all i get is 8 beeps and no display? Any solutions?
Hello,the only way to fix this problem is to prepare original bios file at your USB stick.But first you need to made this USB bootabile(put some universal BIOS fasher software from internet),than put the original file (bios)inside.when its finished try to find another PC (correct),pick up your BIOS chip,(the case of BIOS must be the same as another correct PC!!!!!!!!! IT IS VERY IMPORTANT),than turn on correct PC,run bios ,set USB stick as 1st bootabile device,save changes and restart PC,after that you will see universal Bios mask,you have choice to run bios file you already put on USB stick,DO NOT START FLASHING BIOS!!!!! PICK UP THIS BIOS CHIP FROM HIS CASE,THAN PUT YOUR BIOS CHIP (CHANGE CHIPS UNTIL THIS PC IS STILL WORKING)press enter and this PC will flash your BIOS with correct file.When its finished TURN OFF THIS PC(dont restart).Pick up your bios chip,and put it on your moterboard place for Bios,also put the bios chip from regular (correct)PC to its place,and you are finished.start PC you are using to fix problem ,just to check everything's OK,THAN TURN ON YOUR PC,IT MUST BE WORKING,9its look like risky job but dont worry its ok
I already fix lot of this problems,only check-dont short pins of chip,or turn chip at wrong direction,best luck :)
Dec 16, 2013 | HP Pavilion 1214 QW701AAR Refurbished...
Boot block compatible version ver 0.16 bad bios check sum.bios recovery floppy not find. cd rom not find. i want a solution for this . iam using asus p5rd1-vm motherbord pls help me frnds
Your bios i corrupt. You will need to download bios for your mother board, burn it on a cd and flash your motherboard bios. Go to your manufacturer site for more information on how to flash your bios using CD.
Nov 27, 2012 | Computers & Internet
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
This is my first time building a computer. When I turn the computer on, I get a screen that reads: "Boot Block Compatible Version Ver.022 Bad BIOS checksum. Starting BIOS recovery... Checking...
My first thought is that you have a defective motherboard. I've never seen so many things going wrong except when the board was a dud. It sounds like the BIOS ROM or its interface circuitry is bad. If this board is still under warranty you can probably get it replaced. Try the vendor first. If you bought your board from a company like TigerDirect or Newegg, they're pretty good about replacing defective parts. Then check the manual or Asus website to see what you need to do if the vendor won't exchange it. I have used this same board (purchased from TigerDirect) in a couple of systems, and they went together without a hitch.
Once you've got a working motherboard, it should be pretty much smooth sailing with the rest of the assembly. Good luck and thanks for using Fixya! Please post a followup to let me know when you get your system running.
Dec 26, 2010 | ASUS M4A785M (890552666775) Motherboard
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
Jul 31, 2009 | Acer Aspire 5610-4648 Notebook
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Jan 23, 2009 | Intel Motherboard
Rom bios error
turn off your comp.,go to cmos setup,go to boot option,make your cdrom as the first boot device.insert the support cf of your mboard to cdrom to recover the original rom bios because your bios file was corrupted already.dont turn off your comp, while flashing.
May 19, 2008 | EPoX EP-4PEA+ Motherboard
SL 67FV!
hello.
Use original disc installation maybe the installation disc is not compatible. if your system is branded you need only the windwos recovery disc. but if you try this already maybe you can try updating the bios but im not convence in updating the bios.
For now i will suggest you to change the CD ROM disk maybe this can cause failure installation.
melnavz
Mar 19, 2008 | Intel Motherboard
Computers & Internet Logo
166 people viewed this question
Top Enlight Computers & Internet Experts
Larry Maranto
Jerry Umali
Raymond Solomon
Level 1 Expert
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
